| Author |
Message |
KCTractors Regular
Posted: Sat Feb 16, 2013 6:53 pm Post subject: Back Pressure Valve on a NAA Hydraulics |
Working on a NAA hydraulic system. The 3pt will not do anything, so I took the top cover off after taking the acorn nut off, when I did that I seen the back pressure valve was turned all the way out, so would that be my trouble with the system? Is that just a O-ring that would sit in the cylinder housing or is it something else? When I put the top cover on, I just turn in the pressure valve till it comes against the O-ring , right! I think the cam follower pin is worn to, so how do I get pin out? I just bought the tractor knowing that the hydraulics did not work |
| Back to top |
Harry in Ky Regular
Posted: Sun Feb 17, 2013 8:07 am Post subject: Re: Back Pressure Valve on a NAA Hydraulics |
Are you sure you have adequate flow/pressure from the pump? Your problem may not be in the lift system. |
| Back to top |
KCTractors Regular
Posted: Sun Feb 17, 2013 5:29 pm Post subject: Re: Back Pressure Valve on a NAA Hydraulics |
Yes, the pump is working. Do I have to take all the linkages off to press the follower pin out? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
