Bank Job, Bad Day (no pics)
RBnSC
PostPosted: Sun Feb 17, 2013 5:18 am    Post subject: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
The building and vault straight forward and not difficult. The floor was another matter. 10 to 12 inches thick plenty of rebar. We got our other excavator and ended up shattering the floor with our wrecking ball. We would pull the rebar with one machine and scoop the concrete with the other. Thursday the muffler came lose on the machine I was running so while My brother was carrying a load to the recycler I pulled the work truck to it to tighten the exhaust pipe. The nuts on the clamp were frozen so I grabbed the torch and a welding rod and welded a spot enough to keep the pipes from coming apart. A spark popped over to another compartment and started a fire. I looked for an extinguisher where we always kept several, none. last week we had to put a fuel pump in that truck and BIL put the extinguisher under the spare tire. Fire is going pretty good so I grabbed the other excavator and scooped up water out of the hole where the footer had been and in mid swing the machine quit.(the starter shorted out and melted one battery post). Luckily My brother drove up with the dump truck that had a fire extinguisher and put out the fire out. All in all we lost one wire, one hydraulic hose, a starter and a battery. Haven't been that scared in a while.Took half a day and had all back up and running again.
Ron
Vito
PostPosted: Sun Feb 17, 2013 5:38 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Scary stuff.Good to hear you didn't lose the whole machine.My youngest brother went thru something similar with a dash fire in a Chevy pickup he was plowing snow with.
Vito
jm.
PostPosted: Sun Feb 17, 2013 5:43 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
RB You are lucky... Industry says that if an excavator fire is not put out within the first two minutes the machine is lost. Seems those things burn fast.
fixerupper
PostPosted: Sun Feb 17, 2013 5:54 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
That was close. Glad to hear you got it out in time. Your adrenalin was running in emergency mode for sure. Now you're in for a whole month of good luck. Jim
onefarmer
PostPosted: Sun Feb 17, 2013 5:59 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
"Took half a day and had all back up and running again."
And the other half to calm back down I bet. Glad it worked out though.
RBnSC
PostPosted: Sun Feb 17, 2013 6:03 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Right about that. I was shaking like leaf.
Ron
BAnNC
PostPosted: Sun Feb 17, 2013 6:17 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Glad you're OK. Sounds like the machine will be too.
Was the other time spent going behind the building for a change of tidywhities?
gene bender
PostPosted: Sun Feb 17, 2013 6:46 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Either have a fire watcher or get an ext before starting repair just good sense.
WGWKy2
PostPosted: Sun Feb 17, 2013 7:56 am    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Had that happen two too many times once in a boat, all that water ain't worth a d**m in a boat fire. All I can say is a fire extinguisher in a boat is for those that can't swim.
SweetFeet
PostPosted: Sun Feb 17, 2013 12:44 pm    Post subject: Re: Bank Job, Bad Day (no pics) Reply to specific post Reply with quote
Glad you are ok, and your machine is mostly ok.
Even though it quit on you... pretty good thinking to try and scoop up some water with the other excavator. I don't think that I would not have thought of that in the stress of moment.
