| Author |
Message |
G1355 Long Time User
Posted: Sun Feb 17, 2013 12:49 pm Post subject: External or internal oil pump? |
Looked at a g1355 and looked like this, was wondering if it had the internal or external from the picture, any help appreciated.
| Back to top |
molinegb Long Time User
Posted: Sun Feb 17, 2013 3:18 pm Post subject: Re: External or internal oil pump? |
External. |
| Back to top |
Alan K Tractor Expert
Posted: Sun Feb 17, 2013 4:17 pm Post subject: Re: External or internal oil pump? |
Im not familiar with the 585 engines. How does a person tell what they have? Thank you. |
| Back to top |
Posted: Sun Feb 17, 2013 7:38 pm Post subject: Re: External or internal oil pump? |
I'd like to know how you tell to, the one I looked at I couldn't turn over so it must of been locked up and was missing the fuel pump, what's it worth? |
| Back to top |
G706 Regular
Posted: Sun Feb 17, 2013 7:40 pm Post subject: Re: External or internal oil pump? |
That's the external oil pump on the side of the engine where earlier models (G1000, etc) had the hydraulic pump mounted. The external oil filters are another clue. The G1355 hydraulic pump is on the transmission case. |
| Back to top |
Posted: Sun Feb 17, 2013 8:09 pm Post subject: Re: External or internal oil pump? |
But some g1355s had the internal, how do you tell when it's internal, can you post a picture so I can see the difference. |
| Back to top |
Posted: Sun Feb 17, 2013 8:13 pm Post subject: Re: External or internal oil pump? |
Ok.....(duh on my part) I saw the hydraulic pump and didnt think about the Oliver rear end that the pump is there. I thought the filters were just fuel filters in the picture since my 950s are in that spot. Where do they locate them on the 1355s? |
| Back to top |
Posted: Sun Feb 17, 2013 8:27 pm Post subject: Re: External or internal oil pump? |
Im guessing there would be an absence of the pump and filters and possibly just a "plate" where the pump would be? This is the only pic I have on my computer that shows that side.
| Back to top |
Posted: Sun Feb 17, 2013 8:31 pm Post subject: Re: External or internal oil pump? |
Funny thing, LOL I ran across the same tractor pictures and I saved the "other" side picture to my computer...
| Back to top |
Posted: Sun Feb 17, 2013 8:33 pm Post subject: Re: External or internal oil pump? |
So no filters = internal
Filters= external
Know I'm starting to wonder if it had filters or not.... It said mm on the front so its a early one thought it might of been converted starting to second guess myself again. Wish it wasn't locked up, still want it but its gonna take a fortune. |
| Back to top |
Posted: Sun Feb 17, 2013 8:51 pm Post subject: Re: External or internal oil pump? |
That is what Im guessing. No filters AND no pump below the injection pump. Ive only been around a couple 1350s and not sure if Ive ever really been around a 1355. I sure like them though. |
| Back to top |
mm fan Regular
Posted: Mon Feb 18, 2013 5:05 am Post subject: Re: External or internal oil pump? |
In this pic you can see the little pump mounted low on the engine. This is a transmission cooler pump. When it has the external oil pump, this little pump is replaced with the big pump shown in the other pictures. The external pump is the only ones with spin on oil filters, as the internal pump filter is in the oil pan. THese tractors use the stanadyne sqaure glass fule filters like alot of John Deere's and others. |
| Back to top |
Posted: Mon Feb 18, 2013 5:15 am Post subject: Re: External or internal oil pump? |
Lol I took the first one I seen off google. |
| Back to top |
Posted: Mon Feb 18, 2013 5:18 am Post subject: Re: External or internal oil pump? |
Alright I see what your talking about now. I'm gonna have to check. Thought the one I looked at had spin on filters but I'm gonna have to double check, thanks for explaining I understand now. |
| Back to top |
kb88 Regular
Posted: Wed Feb 20, 2013 6:39 am Post subject: Re: External or internal oil pump? |
Looks like they replaced the internal one with an external because it has the early oil cooler.On the white 2-150 the filters are on the oil cooler its all one unit. |
| Back to top |
