Rear mounted loaders, your thoughts
Joshua Rod
PostPosted: Sun Feb 17, 2013 3:27 pm    Post subject: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
In the last several years I have been seeing more and more larger tractors, 100~200hp tractors, at dealerships with rear mounted loaders. Is there much of a difference in weight distribution and handling when using these compared to front mounted loaders? Because of the configuration can they lift more weight, being over the beefier rear axle?
Last question; being that the operator faces the rear are these dedicated loader tractors or can they still be used for fieldwork, utility, anything else?
Always been curious......
DeltaRed
PostPosted: Sun Feb 17, 2013 5:53 pm    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
I think what you're refering to is a 'bidirectional' tractor.The seat swivels to run foreward or backward.They run backward as a loader,swather....They can run foreward to do normal 'tractor work'.
rabbit
PostPosted: Sun Feb 17, 2013 6:01 pm    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
Does anyone still make "bidirectional tractors"?
Last ones I saw were made by Versatile, and they're not around anymore.
Joshua Rod
PostPosted: Sun Feb 17, 2013 6:05 pm    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
Are there controls and steering columns in front and back then? Driving through the lots, maybe I haven't noticed.
DeltaRed
PostPosted: Sun Feb 17, 2013 6:15 pm    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
There is just one set of controls/seat on a rotating base. Bidirectionals are now being made by Ford/New Holland
hd6gtom
PostPosted: Mon Feb 18, 2013 10:19 am    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
Joshua, There used to be several around central Iowa. These are loaders that mount to the 3 point arms. Most of them I saw were used in feedlots loading or feeding silage. It has been 30 years since I was around 1, I don't remember how they operated. Everyone I knew liked them.
Ken Macfarlane
PostPosted: Tue Feb 19, 2013 11:47 am    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
The rear mounted loaders are popular on big tractors as they are easy to mount, can be shared between multiple tractors easily without brackets and fairly good visibility on big tractors vs a front loader.
They need large tractors for useful lift ratings. Small tractors don't weigh enough.
scotc
PostPosted: Thu Feb 21, 2013 9:15 am    Post subject: Re: Rear mounted loaders, your thoughts Reply to specific post Reply with quote
In the deal with the Case/ NH merger, I believe the bi-directionals got sold off to Buhler along with the Ford 4x4 line.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
