| Author |
Message |
714_run New User
Posted: Mon Feb 18, 2013 12:59 pm Post subject: Homemade Cab on 641 Ford |
Pictures of a home-made cab with integral roll cage on a 641 Ford tractor used in the woods and for New York cold winters.
| Back to top |
Vito Tractor Guru
Posted: Mon Feb 18, 2013 1:52 pm Post subject: Re: Homemade Cab on 641 Ford |
Nice looking cab.I don't know how it will work as a ROPS.Looks to weak but this is my opinion.Hopefully you will never find out.
Vito |
| Back to top |
Scott(MO) Regular
Posted: Mon Feb 18, 2013 6:42 pm Post subject: Re: Homemade Cab on 641 Ford |
Very Nice Job! That will keep that 0 degree wind where it belongs! Great Job! |
| Back to top |
Royse Tractor Expert
Posted: Mon Feb 18, 2013 6:51 pm Post subject: Re: Homemade Cab on 641 Ford |
Looks great! How did you hinge and latch the doors?
Do they open to the front like a car door or the the rear? |
| Back to top |
714_run New User
Posted: Tue Feb 19, 2013 3:22 am Post subject: Re: Homemade Cab on 641 Ford |
sliding doors |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13167 Location: Coyote Flats,Tx
Posted: Tue Feb 19, 2013 3:41 am Post subject: Re: Homemade Cab on 641 Ford |
Nice looking shop built cab. Is it very noisy inside of it with engine running? What is the purpose of the big blue hook on the center link mounting bracket? |
| Back to top |
Shoepeg Regular
Posted: Tue Feb 19, 2013 7:44 am Post subject: Re: Homemade Cab on 641 Ford |
Sweet! Great looking job! |
| Back to top |
714_run New User
Posted: Tue Feb 19, 2013 11:40 am Post subject: Re: Homemade Cab on 641 Ford |
big blue hook goes on draw bar to use toe chain , cab is mounted on 1/4 " thick rubber not to noisey |
| Back to top |
Tony Jacobs Long Time User
Posted: Tue Feb 19, 2013 12:15 pm Post subject: Re: Homemade Cab on 641 Ford |
I hate to burst your bubble but that cab has absolutely no roll over protection at all . If you looked at a REAL ROPS Bar before you built it you would see that the bar and the mounting is about 4 times the size of what you have on your cab(or you could have intergrated a real rops bar into your cab) . While it will keep you out of the weather and warm and you may not get hurt if something small falls on it don't rely on it to do much if you roll over . Unfortunately you just may find out fast how it will crush if you start towing from your big blue hook mounted that high on the rear axle housing . YOU NEVER EVER TOW ANYTHING FROM THAT HIGH OF A MOUNTING POSITION UNLESS YOU WANT TO FLIP THE TRACTOR OVER BACKWARDS . Having grown up in the Family Logging Business and rolling over one of our John Deere 548 Graple/Cable Skidders once and laying our John Deere 643 C Shear Head on its side shearing Red Pine for Telephone Poles I know what it takes to survive a roll over and that is not it so you best be careful and not get to brave with it . Thanks Tony |
| Back to top |
sotxbill Tractor Expert
Posted: Wed Feb 20, 2013 4:40 pm Post subject: Re: Homemade Cab on 641 Ford |
| 714_run wrote: | (quoted from post at 15:59:36 02/18/13) Pictures of a home-made cab with integral roll cage on a 641 Ford tractor used in the woods and for New York cold winters.
ABSOLUTLY MOVE THE CLEVIS!!!!!!!!!!! Dont even store it there or you will kill who ever borrows your tractor. |
| Back to top |
Tx Jim Tractor Guru
Posted: Thu Feb 21, 2013 3:18 am Post subject: Re: Homemade Cab on 641 Ford. |
| TONY JACOBS wrote: | | (quoted from post at 15:15:13 02/19/13) Unfortunately you just may find out fast how it will crush if you start towing from your big blue hook mounted that high on the rear axle housing . YOU NEVER EVER TOW ANYTHING FROM THAT HIGH OF A MOUNTING POSITION UNLESS YOU WANT TO FLIP THE TRACTOR OVER BACKWARDS . Thanks Tony |
Tony
I agree on the big blue hook. That's the reason I inquired about it. A total No-No for pulling anything. |
| Back to top |
NWMO 901 SOS Long Time User
Joined: 24 Nov 2006 Posts: 1379 Location: St. Joseph, MO
Posted: Thu Feb 21, 2013 5:10 am Post subject: Re: Homemade Cab on 641 Ford |
| 714_run wrote: | | (quoted from post at 14:40:20 02/19/13) big blue hook goes on draw bar to use toe chain , cab is mounted on 1/4 " thick rubber not to noisey |
714_run,
Very nice work on your tractor, it looks great. Based on your photos, it appears you have some time in the seat and know how to properly use it. We do get some folks with less experience here, so safety issues are commonly pointed out, though that looks like a fine place to carry your tow hook, assuming the operator knows good pulling practices, which you clearly do. With the wheel weights, front bumper set-up and cab, you are set for just about anything. I'm betting you have a set of chains for it as well, which pretty well completes the package. Nice tractor, thanks for sharing.
Chris |
| Back to top |
Jim.UT Tractor Guru
Posted: Thu Feb 21, 2013 4:51 pm Post subject: Re: Homemade Cab on 641 Ford |
Do I see a sealed beam headlight where the emblem used to be? |
| Back to top |
Posted: Fri Feb 22, 2013 5:38 am Post subject: Re: Homemade Cab on 641 Ford |
Good eyes Jim,
Based on his other improvements, I bet he get lights on that new Cab before long.
Chris |
| Back to top |
