Got my rear end apart on my m (pic)
jdetig1
PostPosted: Mon Feb 18, 2013 6:33 pm    Post subject: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Well I tore the rear end down found 5 teeth chipped on one bull gear and teeth chipped on the pinion shaft that drives it. So I got those off eBay this morning. Took all the bearings out and all of them are perfectly fine gonna re use them. Putting new seals in and putting it back together. Having a heck of a time getting the axle back through the bull gear. Left the wheel on mite end up taking that off yet to get the axle back through bull gear
LMack
PostPosted: Mon Feb 18, 2013 7:00 pm    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
I would say that you are going to take that wheel off.
sgtbull
PostPosted: Mon Feb 18, 2013 7:16 pm    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
HOLY COW! You're going to get oil ALL OVER your ceiling!
Cjet
PostPosted: Mon Feb 18, 2013 7:40 pm    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
We bought a Farmall M that had a broken bull gear and it had pushed the broken tooth thru the bottom of the gear case. I would inspect the case under the bull gear before reassembly.
armand tatro
PostPosted: Mon Feb 18, 2013 8:53 pm    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
One fall we had a broken axel on the 400 out in the field with the 2MHD mounted corn picker on. Took the live PTO assy off and removed the broken stub axel from the bull gear with a porta-power jack working thru the PTO mounting hole in the casing. Lifting that bull gear and lining up the splines to get the new axel thru the hole in the bull gear was a bit of a challenge! Doing all that work with the top cover off would be a piece of cake! By the way we pushed 2 6X6 blocks of wood into the ground before the 8 ton bottle jack stared to lift the rear housing. Started about 10 in the mourning and was back picking just after 3 in the afternoon. Three of us working on it. Have fun! Armand
leon
PostPosted: Tue Feb 19, 2013 3:15 am    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Escaped me for a minute 'till I scrolled back and looked at pictures. Thanks for starting my day with a smile.
mkirsch
PostPosted: Tue Feb 19, 2013 5:01 am    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
At least the gears will fall right out once you get them unbolted.
Duner Wi
PostPosted: Tue Feb 19, 2013 5:35 am    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Take a peek at the pinion carrier too. Crack can be not very obvious.
Dave Sherburne NY
PostPosted: Tue Feb 19, 2013 9:11 am    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Looks like my grandson's except his wheels are on the bottom
Jason the Red
PostPosted: Tue Feb 19, 2013 6:39 pm    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Hang onto that grille!!! It looks to be in pretty good shape.
dej(Jed)
PostPosted: Wed Feb 20, 2013 9:35 am    Post subject: Re: Got my rear end apart on my m (pic) Reply to specific post Reply with quote
Stop speed shifting it and double clutch it between 4 and 5th.
