OT-16hp Briggs I/C motor
G6 at Snook, TX
PostPosted: Tue Feb 19, 2013 7:02 am    Post subject: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
Where would I find the model/serial number off of a Briggs 16hp I/C motor? I have looked, but have not found a plate or impression. The motor is attached to a Lincoln Weldanpower 225.
Bob
PostPosted: Tue Feb 19, 2013 7:53 am    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
It will be stamped into the sheet metal "cowling" around the flywheel. Is the engine a flat twin?
G6 at Snook, TX
PostPosted: Tue Feb 19, 2013 8:17 am    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
It is a flat twin.
pconnie..ks.
PostPosted: Tue Feb 19, 2013 9:25 am    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
if you cant find it..i have the same welder..hth phil
G6 at Snook, TX
PostPosted: Tue Feb 19, 2013 9:52 am    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
I need the model number for the carburetor. It needs a rebuild badly and I have sent it in to a local Briggs shop for repair, and they need to order the right kit.
Bob
PostPosted: Tue Feb 19, 2013 11:50 am    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
So you are not seeing it at either of the two locations the red arrows point to in the illustration?
G6 at Snook, TX
PostPosted: Tue Feb 19, 2013 12:43 pm    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
I am at work now. Check it tonight again.
billy boy2
PostPosted: Tue Feb 19, 2013 1:14 pm    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
G6 at Snook, TX wrote:
(quoted from post at 20:52:14 02/19/13) I need the model number for the carburetor. It needs a rebuild badly and I have sent it in to a local Briggs shop for repair, and they need to order the right kit.
If the Briggs shop doesn't know or can't find the model # are you sure you want them to rebuild your carb? If they're stamped, and there's a little rust/oil/grease/dirt, they may have to scratch around a little to find them.
G6 at Snook, TX
PostPosted: Tue Feb 19, 2013 5:53 pm    Post subject: Re: OT-16hp Briggs I/C motor Reply to specific post Reply with quote
Found it. I had pulled the carburetor and taken it to them. Anyhow, it was stamped into the shield next to the plug. Had to wire brush it up good to read it.
326437-758-01 8506241
Last edited by G6 at Snook, TX on Tue Feb 19, 2013 5:54 pm; edited 1 time in total
