Need a part for a John Deere Van Brunt Drill
Ken Sweet
PostPosted: Tue Feb 19, 2013 2:16 pm    Post subject: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Here is a picture of what I am looking for. I need
one of the lower castings that receives the drop
down hose. Let me know if you have that casting you
could part with one and price. Thanks, Ken Sweet
Bob
PostPosted: Tue Feb 19, 2013 2:39 pm    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
You must need a "boot" for a single disc drill?
What is the drill model?
What is the number on the casting?
Hard Iron bearing or ball bearing? (newer than 1961 or older)
Short or long? (drag bars for each disc alternate between short and long)
LH or RH? (side of the boot the disc mounts to)
The drill you have MAY be similar to the model B in the .pdf parts catalog at the link below, from which you cold post a part number (if different from the number on your casting).
Model B drill
Tx Jim
PostPosted: Wed Feb 20, 2013 4:13 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Ken
Here's a list of boots used on the 8000 series drills. The same boots(part #s) also were used on the earlier rubber tired drills such as the model B,FB,FB-A & FB-B which are the ones I'm familiar with. IIRC the number is cast into the boot. The AF boot & hard iron brgs utilized the same boot. Older iron wheel drills utilized a a different boot for mounting hard iron brgs as the hole was "square"
KK168M SEED BOOT 1 ( Z82M) SHORT OPENER, R.H.
KK169M SEED BOOT 1 ( Z83M) SHORT OPENER, L.H.
BB3098M SEED BOOT 1 ( A634M) LONG OPENER, R.H.
BB3099M SEED BOOT 1 ( A635M) LONG OPENER, L.H.
QQ1264M SEED BOOT 1 ( M61848) SEMI-DEEP, LONG OPENER, R.H.
QQ1265M SEED BOOT 1 ( M61849) SEMI-DEEP, LONG OPENER, L.H.
Ken Sweet
PostPosted: Wed Feb 20, 2013 7:07 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
The casting # shown in the picture on the left side
of the picture is 6B- A634MLR. Need the whole
assembly and disc also. Standing behind the drill,
this piece is on the left side with single disc
opener discs. Thanks Ken Sweet
dmiller
PostPosted: Wed Feb 20, 2013 7:36 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
What model are you working on. I have an FB that I use and an (I believe) SS that I'm taking a few of the cast iron boots off of as repair parts (same casting number).
The rest of the drill I'm probably going to sell (yard ornament???)
I'm in Montana e-mail if interested
Tx Jim
PostPosted: Wed Feb 20, 2013 9:11 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Ken
Does your drill have LH & RH openers? Some drills had the openers that went only one direction.
Ken Sweet
PostPosted: Thu Feb 21, 2013 9:00 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
The one I need is on the left side standing behind
looking forward. Ken Sweet
Tx Jim
PostPosted: Thu Feb 21, 2013 9:47 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Ken Sweet wrote:
(reply to post at 12:00:12 02/21/13)
That should sub to a BB3099M for just the boot
Ken Sweet
PostPosted: Thu Feb 21, 2013 10:13 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Jim, that is correct--I could use that whole assembly from the disc all the way up to where it bolts on. Ken Sweet
Tx Jim
PostPosted: Thu Feb 21, 2013 11:25 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Your drill is rubber tired isn't it??
Ken Sweet
PostPosted: Thu Feb 21, 2013 11:28 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
Yes it is rubber tired. Ken Sweet
Tx Jim
PostPosted: Thu Feb 21, 2013 11:40 am    Post subject: Re: Need a part for a John Deere Van Brunt Drill Reply to specific post Reply with quote
I have a steel wheel drill that has a few openers on it but they have the wrong boots for what you need.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
