| Author |
Message |
redIHplower640 Guest
Posted: Tue Feb 19, 2013 3:44 pm Post subject: JD M Head Question? |
Have a M the coolant plug in the cylinder head has rusted through at the bottom of the head where it meets the head gasket. Is this just a standard freeze plug and do I realy need to install a new one? |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5623 Location: Hutchins, TX
Posted: Wed Feb 20, 2013 6:23 am Post subject: Re: JD M Head Question? |
The hole in the top, left, rear cylinder head requires a 1/2 inch square head pipe plug.
If the end of the complete heat indicator (temperature gauge) is installed in the cylinder block, then a 1/2 inch square head pipe plug should be installed in the cylinder head.
Hope this helps. |
| Back to top |
CaseRider New User
Posted: Wed Feb 20, 2013 2:27 pm Post subject: Re: JD M Head Question? |
Do you mean rusted bad like this one in the red circle? (JD Part number M 460T)
If this is the one you mean, it's more of a flow restrictor than a standard freeze plug...looks like a washer. Why not replace it since you already have it this far apart?
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
