| Author |
Message |
old Fel-Pro rep. Guest
Posted: Tue Feb 19, 2013 6:37 pm Post subject: fuel in oil |
I have a 950 the is over full with deisel. I have full power. any help? |
| Back to top |
woodbutcher Long Time User
Posted: Wed Feb 20, 2013 3:26 am Post subject: Re: fuel in oil |
I solved that problem with my 2040 by replacing the lift pump. I thought it had to be either that or the injector pump causing my problem.
Butch |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13196 Location: Coyote Flats,Tx
Posted: Wed Feb 20, 2013 4:47 am Post subject: Re: fuel in oil |
Since 950 doesn't have a lift pump then the problem could only be leaking inj pump or very bad injector. Does engine have a miss or smoke badly? |
| Back to top |
Dieseltech Long Time User
Posted: Wed Feb 20, 2013 5:46 am Post subject: Re: fuel in oil |
Use two wrenches, remove all injection lines at injection pump. Now retorque pump delivery valve fittings, 22-25 ft-lb and replace all lines. This is worth a try before pump is removed for complete reseal. This pump has copper gaskets under the barrels that can leak, may just need retorqued again. Most inline pumps do not seal like this model does. |
| Back to top |
Posted: Wed Feb 20, 2013 2:33 pm Post subject: Re: fuel in oil |
Thanks for the replies. Sorry about the spelling, I was tired. I will try this when I get home. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
