| Author |
Message |
heybusdriver Long Time User
Joined: 25 Nov 2000 Posts: 817 Location: Surrey B.C. Canada
Posted: Tue Feb 19, 2013 6:42 pm Post subject: What drill size |
What drill size would you use to dill a hole to tap a 1/4 grease zerk?
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
KrisNMo Regular
Joined: 05 Mar 2009 Posts: 53 Location: Troy, Missouri
| Back to top |
joe in wilkinson New User
Posted: Tue Feb 19, 2013 7:22 pm Post subject: Re: What drill size |
#3 drill = .213" dia.
Could also use a 7/32" which is .218" dia.
This is for 1/4-28 threads. |
| Back to top |
BMACK518N Regular
Posted: Wed Feb 20, 2013 6:35 am Post subject: Re: What drill size |
1/4-18 NPT?
1/4-28?
1/4 Drive?
All take a different bit size. |
| Back to top |
Posted: Wed Feb 20, 2013 8:47 am Post subject: Re: What drill size |
Like I said, grease zerk, you tell me.
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
Posted: Wed Feb 20, 2013 8:59 am Post subject: Re: What drill size |
The zerk is about 1/4 long with about 4 threads, i's just a grease zerk , not to major of an issue, is it 1/4 -18 NPT, 1/4-28 or 1/4 drive? Sorry to ask such a technical question,
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
R Geiger Tractor Expert
Joined: 19 Apr 2009 Posts: 1771 Location: Banks, Oregon
Posted: Wed Feb 20, 2013 9:03 am Post subject: Re: What drill size |
| heybusdriver wrote: | (quoted from post at 01:59:01 02/21/13) The zerk is about 1/4 long with about 4 threads, i's just a grease zerk , not to major of an issue, is it 1/4 -18 NPT, 1/4-28 or 1/4 drive? Sorry to ask such a technical question,
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
Google is your friend. before you can figure out whcich drill to use you need to figure out what you have. seen picture charts for straight and taper threads by looking at google for zeerk fittings. |
| Back to top |
JCinKY Regular
Posted: Wed Feb 20, 2013 9:35 am Post subject: Re: What drill size |
| heybusdriver wrote: | (quoted from post at 09:59:01 02/20/13) The zerk is about 1/4 long with about 4 threads, i's just a grease zerk , not to major of an issue, is it 1/4 -18 NPT, 1/4-28 or 1/4 drive? Sorry to ask such a technical question,
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
If it is 1/4" and most likely NPT, it is close enough to course thread 1/4 - 20. Get a #6 drill and a 1/4-20 tap and you should be fine. These are very common sizes and are probably easier to find than NPT (maybe cheaper). Its just a grease zerk... |
| Back to top |
BMACK518N Regular
Posted: Wed Feb 20, 2013 10:05 am Post subject: Re: What drill size |
Study up, more to grease zerk's than you think. Even metric sizes now. |
| Back to top |
Caryc Long Time User
Joined: 03 Mar 2010 Posts: 1166 Location: Southern Cal.
Posted: Wed Feb 20, 2013 10:17 am Post subject: Re: What drill size |
| heybusdriver wrote: | (quoted from post at 19:42:43 02/19/13) What drill size would you use to dill a hole to tap a 1/4 grease zerk?
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
A screw pitch gauge is your friend. Seriously, they are not that expensive and do come in handy sometimes. Every tool box should have one.
Except for some of them ol' geezers who can look at any thread and tell you what it is.
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5869 Location: Myersville, MD
Posted: Wed Feb 20, 2013 10:29 am Post subject: Re: What drill size |
| BMACK518N wrote: | | (quoted from post at 14:05:48 02/20/13) Study up, more to grease zerk's than you think. Even metric sizes now. |
Sometimes the advice you get here isn't even worth what you pay for it which is zero. JC also needs to do some studying on thread/pipe sizes. The pitch diameter of a 1/4" NPT male pipe thread is .447 at the first thread (small end) of the taper. Good luck screwing that into a 1/4 tapped hole of any pitch
TOH
| Back to top |
JCinKY Regular
Posted: Wed Feb 20, 2013 11:04 am Post subject: Re: What drill size |
I apologize for not being clear. I assumed you simply measured the diameter of the zerk and called it 1/4". I do understand the difference between NPT and UNF/UNC thread counts, pitches, and nominal diameters.
You wanted a drill size. If the thing is 1/4" OD measured, a #6 drill is .204, 1/4-20 tap is, well, .250. Close enough for a grease zerk in my book, but thats just me. Heck, stick it in a nut and see which one works and go from there.
Had some 6mm zerks on a mower I am restoring now. Bought a bag of 20, got a #6, 1/4" tap and the work like the should. Why spend the time and money to get a 6mm tap.
Again, this is all based on the assumption that you have measured the OD of the fitting at 1/4". I apologize for any oversights or poor information given. You know what they say about assumptions, the make an A## out of you and me...in this case only me.
Sorry |
| Back to top |
JCinKY Regular
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
