Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
model b pistons questions
Post new topic    Yesterday's Tractors Forum Index -> John Deere
warren woodrow
PostPosted: Tue Feb 19, 2013 7:59 pm    Post subject: model b pistons questions Reply to specific post Reply with quote
Finally got pistons out of my 1941 model B . Serial # 102048 . I have one bad cylinder which I believe will require a maximum overbore . Is the maximum .125 and is that 4 11/16 inches . Some on this board have said that a late model B piston will fit .125 overbore and pistons will fit my rods and pins . Is this all correct as I am ready to take it to a machine shop.
Mike N Mo
PostPosted: Tue Feb 19, 2013 8:31 pm    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
A 1941 B would have had a stock bore of 4.5", so a late B standard bore piston would require an overbore of 3/16" (4.6875"). This should work ok unless the block has excessive rust pitting on the water side of the cylinders. I've read on this forum that .125" over pistons (4.625") aren't available for the early styled B's, but I've never researched that myself. Just passing along the hearsay. I think I would have the pistons before having the block machined. You can always return the un-used new pistons, but you can't undo the machining done on the block. Good luck with your project. Mike
gtx1967jewison
PostPosted: Wed Feb 20, 2013 4:45 am    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
These things have alot of iron in them. As an example, no pistons are available for a model R so they are often bored 375 thousandths! Thats 3/8". To use 720/820 pistons. I would call Ray at Extreme Tractor Parts or Josh Blackburn. They both have built alot of these & both make custom pistons. I believe you can use Late B pistons. Get some new aluminum ones. They are both on the pulling forum often.
MSD
PostPosted: Wed Feb 20, 2013 8:41 am    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
Can you reuse the old pistons or do you have something else in mind? It might be cheaper to sleeve it and use the original pistons than boring it and putting new ones in. Last A we did it was $50 for the sleeve installed plus boring charges.
warren woodrow
PostPosted: Wed Feb 20, 2013 10:16 am    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
Had been led to believe sleeving was alot more expensive. I think my pistons are good and at that price range I would rather sleeve and use my originals.
warren woodrow
PostPosted: Wed Feb 20, 2013 11:34 am    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
Machine shop I contacted said $700.00 to sleeve and bore both cylinders. Needless to say I will contact others. Always someone wanting to make a killing....... instead of a living.
gtx1967jewison
PostPosted: Wed Feb 20, 2013 2:05 pm    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
New ones are half the weight, more compression/power, barely more than the cost of rings for your worn originals. To sleeve it requires boring much farther than it does with new pistons. Its always cheaper to buy pistons & bore than buy rings bore sleeve & finish bore the sleeve. & a much nicer outcome imo.
JD Man MI
PostPosted: Wed Feb 20, 2013 3:01 pm    Post subject: Re: model b pistons questions Reply to specific post Reply with quote
Use late B pistons, I've done it and it works great
