| Author |
Message |
AF70 Guest
Posted: Wed Feb 20, 2013 12:21 pm Post subject: 70 Flywheel |
I have a cracked flywheel on my '53 all fuel and need to replace. All "new" ones seem to be taperlock style for $800-%900. My splines are fine, will a taperlock work? I'm close to Abilene Machine and can get one there w/o shipping. Does that price seem OK? |
| Back to top |
48JDA Regular
Posted: Wed Feb 20, 2013 1:35 pm Post subject: Re: 70 Flywheel |
I don't know if that style will work but I found a regular flywheel on ebay they want 285 for and 125 to ship it. but i bet the guy would take less if you offered him.
http://www.ebay.com/itm/John-Deere-70-rowcrop-tractor-JD-engine-motor-flywheel-ring-gear-/321063838895?pt=LH_DefaultDomain_0&hash=item4ac0e564af |
| Back to top |
gtx1967jewison Tractor Expert
Posted: Wed Feb 20, 2013 1:59 pm Post subject: Re: 70 Flywheel |
Taperlock will work & is a much better setup. |
| Back to top |
Mike M Tractor Guru
A taperlock will work,but be sure it is for your gas model and not a diesel !!!! I'm betting they are different. |
| Back to top |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 271 Location: central Mass
Posted: Wed Feb 20, 2013 3:08 pm Post subject: Re: 70 Flywheel |
IMO the taper lock is the way they should have been built in the first place. Our 70 gas went through two stock flywheels before we put a taper lock on it. Should never have another problem. That was about 8 years ago and I think we paid around $500 for it. |
| Back to top |
Blksmok Regular
Posted: Wed Feb 20, 2013 4:04 pm Post subject: Re: 70 Flywheel |
AF70...in my experience a cracked flywheel is the result of it coming loose and then overtightened in an effort to keep from knocking. Although the splines may look good on the crank they are probably slightly worn and a taperlock is the best way to fix the problem. Putting a used or NOS JD flywheel on a worn crank will not work. You cannot have any radial movement of the FW on the crank (spline/groove width worn) or vertical movement (over diameter of the crank worn). If you go with the taperlock, make sure you follow the installation instructions closely. |
| Back to top |
Tracy Brown Regular
Posted: Thu Feb 21, 2013 5:35 am Post subject: Re: 70 Flywheel |
I have a 70 LP coming that I am go to part out. It looked to be complete. |
| Back to top |
buck eye al Guest
Posted: Thu Feb 21, 2013 2:33 pm Post subject: Re: 70 Flywheel |
I know you didn't ask this but if you have any reservations about or over the taper lock flywheel, I installed one on my 70D back in about 1983 & have not regretted it! Original cracked along one of the bolt holes & started making noise. Mr.Taperlock stopped that noise & I have about 1900 hours on it.
Later. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23715 Location: in front of computer
Posted: Thu Feb 21, 2013 2:49 pm Post subject: Re: 70 Flywheel |
I would trade my heap of parts 70LP for your whole 70LP and some cash if you were nearby. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
