rod questio
outsidersag
PostPosted: Wed Feb 20, 2013 3:37 pm    Post subject: rod questio Reply to specific post Reply with quote
Will 2670 rods fit on a 930 crank?
Case Nutty 1660
PostPosted: Wed Feb 20, 2013 4:46 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
no 930 would have what is called a "small" crank
the 2670 has the "large" crank
outsidersag
PostPosted: Wed Feb 20, 2013 7:44 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
Will 2290 rods work on the 930 crank and fit the 2670 pistons?
1370rod
PostPosted: Wed Feb 20, 2013 8:26 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
The 2290 has smaller wrist pins that a 2670, use the 22's pistons, still a 504.
Case Nutty 1660
PostPosted: Wed Feb 20, 2013 8:31 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
no both rod ends are larger on the big cranks,
1370/1470/1570/2390/2590/2470/2670 all have big cranks 2090/2290/2094/2294 have the small cranks
1370rod
PostPosted: Wed Feb 20, 2013 8:34 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
Wanted to add I just tossed a set out of a 22 this week your welcome to have if you want something to play with.
outsidersag
PostPosted: Thu Feb 21, 2013 10:57 am    Post subject: Re: rod questio Reply to specific post Reply with quote
I would be very interested in them
outsidersag
PostPosted: Thu Feb 21, 2013 11:01 am    Post subject: Re: rod questio Reply to specific post Reply with quote
Want to make my purple 900 into a 504
1370rod
PostPosted: Thu Feb 21, 2013 5:42 pm    Post subject: Re: rod questio Reply to specific post Reply with quote
Just call 507 926 5229 if you want them. They are on the old parts pile outside, snow could hide them for awhile.
jon f mn
PostPosted: Fri Feb 22, 2013 6:30 am    Post subject: Re: rod questio Reply to specific post Reply with quote
I did a 930 once, there are many things that need changing over if you are going to use the newer heads. When you bore the block you will hit the water pump a bit in the front hole. It won't cut enough to hurt water pumping, but it can walk the boring machine because it only hits on the front. If that happens you can use JB weld on the bottom cut and recut it, I know that for a fact. lol. You will need rocker arms, push rods and I remember a problem with using 2090 sleeves but I don't remember why. I used them from a 1370. The head bolts are an issue because the 30's are to long and the 70/90's are larger diameter. There will also be an extra head bolt on the newer heads, I just plugged it with a frost plug.
View user's profile AIM Address
