Industrial G-pic
FactoryFarmer
PostPosted: Wed Feb 20, 2013 9:29 pm    Post subject: Industrial G-pic Reply to specific post Reply with quote
I wanted to do something really different on my pulling tractor so I wanted to go with an industrial look.
The body work is not perfect but I did not have much to start with. I grill screens will straighten up fine when bolted to the radiator.
On the hood I cut out the bump where the steering rod goes and filled it in as well as where the fuel necks would be. I finally found the old style aluminum industrial badges to go on the side which I think will really set it off.
Does anyone else have any ideas of what I can do around the tractor to make it look more "industrial"?
Mike M
PostPosted: Thu Feb 21, 2013 6:09 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
You would have to get rid of those nice grilles and put a heavy cast iron front end on it .
tim s
PostPosted: Thu Feb 21, 2013 6:41 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
You sure got a good looking paint job going on there. Revue the different industrial tractors (which I'm sure you already have) and see what else "may' join the party to enhance your intended look..That's what I did with my 60C project..
gloveriadmit
PostPosted: Thu Feb 21, 2013 8:01 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
how do you plan to steer it without the steering shaft opening, and all industrials had filler neck openings in the hoods so whats the point of that? Industrials weren't any different than the green ones other than paint except the AI, BI, DI, and 80, 820, 830 and 440. Had Deere actually made a G industrial, it would have just been yellow.
pbb
PostPosted: Thu Feb 21, 2013 4:56 pm    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
That looks good and will be diffrent.In Green magazine a year or two back had a girl on a 40 or 420 pulling tractor painted industral orange that looked sharp.I know a guy that has a B pulling tractor painted black.I think it will be cool to have something diffrent at the pulls.
WeirdDeere
PostPosted: Fri Feb 22, 2013 2:36 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
It's great to see something different, especially when it's in industrial yellow!
The only other industrial "feature" I can think of at the moment would be square drilled and tapped mounting pads on your frame for intergral equipment.
Be sure to post pictures of the beast when you're done!
Brandon
FactoryFarmer
PostPosted: Fri Feb 22, 2013 7:25 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
Thanks alot for the comments.
gloveriadmit wrote:
(quoted from post at 09:01:58 02/21/13) how do you plan to steer it without the steering shaft opening, and all industrials had filler neck openings in the hoods so whats the point of that? Industrials weren't any different than the green ones other than paint except the AI, BI, DI, and 80, 820, 830 and 440. Had Deere actually made a G industrial, it would have just been yellow.
It has a rack and pinion front end, why put filler necks in the hood if you don't need them? I don't use the original gas tank and I like to make things look clean.
pbb wrote:
(quoted from post at 17:56:31 02/21/13) That looks good and will be diffrent.In Green magazine a year or two back had a girl on a 40 or 420 pulling tractor painted industral orange that looked sharp.I know a guy that has a B pulling tractor painted black.I think it will be cool to have something diffrent at the pulls.
Thanks, thats the plan is to be different. It will already be very different with disk brakes, a whole new front end, billet flywheel, and turning 3000 RPM. I also figured that some people like red tractors, some people like green tractors, but everyone will like a yellow tractor.
FactoryFarmer
PostPosted: Fri Feb 22, 2013 7:27 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
WeirdDeere wrote:
(quoted from post at 03:36:32 02/22/13) It's great to see something different, especially when it's in industrial yellow!
Brandon
Thanks alot Brandon, glad you like it!
I should call it "The Weird Deere" Laughing
tim s
PostPosted: Fri Feb 22, 2013 7:48 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
That's what Lance Little was probably thinking on his "830" super stock...
gtx1967jewison
PostPosted: Fri Feb 22, 2013 8:24 am    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
Where did you get the flywheel made?
Thanks!
FactoryFarmer
PostPosted: Fri Feb 22, 2013 4:46 pm    Post subject: Re: Industrial G-pic Reply to specific post Reply with quote
gtx1967jewison wrote:
(quoted from post at 09:24:49 02/22/13) Where did you get the flywheel made?
Thanks!
A neighbor is making it for me.
