| Author |
Message |
mikekee New User
Posted: Thu Feb 21, 2013 11:46 am Post subject: 404 IH |
novice here were is the dip stick for hydraulic fluid and were do you add it.bought and old tractor has a couple 1 12 90s by gear shift with a nut on top kinda thinking its suppose to go there but not sure on how much.stuck a zip tie down in it to get a level check and just got a drop at the bottom of tie 12 in tie. |
| Back to top |
ralph1111 Regular
Posted: Thu Feb 21, 2013 12:47 pm Post subject: Re: 404 IH |
If I remember correctly their is a pipe plug on left side near the back of the housing which would be the level check, you have all ready found the fill hole.
Ralph |
| Back to top |
mikekee New User
Posted: Thu Feb 21, 2013 1:37 pm Post subject: Re: 404 IH |
And what type of hydraulic fluid should be used. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18455 Location: St. Cloud, MN
Posted: Thu Feb 21, 2013 2:56 pm Post subject: Re: 404 IH |
Hytran (IH) or equivalent. JD transmission fluid is fine. Read the label on all others to be sure it meets the Hytran spec. Jim |
| Back to top |
mowr Long Time User
Posted: Thu Feb 21, 2013 4:07 pm Post subject: Re: 404 IH |
No dipstick. Just a pipe plug in the top of the torque tube just behind the bell (of the bell housing). Drain plug is on the right lower of the same housing. |
| Back to top |
mowr Long Time User
Posted: Thu Feb 21, 2013 4:10 pm Post subject: Re: 404 IH |
Transmission/rear axle housing takes gearlube; does not share with hydraulic system. |
| Back to top |
mikekee New User
Posted: Sun Mar 10, 2013 11:12 am Post subject: Re: 404 IH |
Is this housing under the seat on the left side faceing tractor.,I need to drain the fluid.and you say the feed tube is by the shifter in front of seat.My bucket lifts slow and my hitch is very slow......... |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
