What did I see?
37chief
PostPosted: Thu Feb 21, 2013 7:29 pm    Post subject: What did I see? Reply to specific post Reply with quote
A truck comming toward me the other day, and it looked like a Ford truck body couldn't tell for sure. but fairly new looking, it had a a split windshield. Looked kind of cool. Does any auto maker, make a split windshield now? Stan
John B.
PostPosted: Thu Feb 21, 2013 7:40 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
Do you think it was a custom made truck?
I saw a tractor trailer that passed me on the interstate one time years ago with two steer axles. I've always wondered what the purpose of the two axles were for.
John B.
Dalex
PostPosted: Thu Feb 21, 2013 7:48 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
The two axles are to carry more weight. I've mostly seen them on crane trucks where the boom is carried forward.
Randysouthmississippi
PostPosted: Thu Feb 21, 2013 7:50 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
Some of the heavy haulers here in the south mainly oil field have a few trucks with double steer axles.
Most all of the work over rigs on the road have two steer axles.
scotc
PostPosted: Thu Feb 21, 2013 8:13 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
In Japan (and I would guess other places where space is at a premium) they tend to run single drive axles with tandem steers.
504
PostPosted: Thu Feb 21, 2013 8:19 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
None I have seen, but two windshields are preferred for truck owners. A truck owner will get a DOT fine for a cracked or broken windshield, it is cheaper to only replace one side instead of a whole one piece windshield. But it is cheaper for a manufacture to just slap in a one piece when they build the truck.
waltdavies
PostPosted: Thu Feb 21, 2013 8:59 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
Large truck cranes have two steering axles because of the weight over the front end.
Walt
Stick welding
PostPosted: Thu Feb 21, 2013 9:46 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
Big cement trucks and oilfield bed trucks will have tandem steer axles and it's getting common to see triple drive axles as well as tandem steer axles.
Michael Price
PostPosted: Thu Feb 21, 2013 10:13 pm    Post subject: Re: What did I see? Reply to specific post Reply with quote
Maybe the truck was armor plated. Ive seen new pickups, SUV, and Cadillacs with split windshields because they are armored.
BAnNC
PostPosted: Fri Feb 22, 2013 4:43 am    Post subject: Re: What did I see? Reply to specific post Reply with quote
Could it have been made for use as an armored car? They have split windshields cause of the bullet proof glass. Just thinking.
ericlb
PostPosted: Fri Feb 22, 2013 5:06 am    Post subject: Re: What did I see? Reply to specific post Reply with quote
we have some of those around here too, they are armored vehicles, some carry money transfers some carry other stuff that is valuable, the big trucks with muliple steer axles are for weight distribution, we're seeing straight trucks with as many as 6 axles under them to comply with the interstate weight laws as the demand for larger trucks hauling more material in the vocational market, dump trucks and cement trucks out here can have 1 steer axle, folowed by 2 air lift non powered but steerable axles, then 2 powered drive axles, followed by 1 high lift non powered but steerable axle, this last one when in the raised position will rest on top of the truck body this along with oversize bodies, allows a truck that used to be limited to a gross weight of 50,000 lbs to be able to haul 80,000 lbs, while this setup cant use some roads due to the bridge laws, it does help tremendously as here in the west vocational trucks have to run longer distances to deliver their products, 2 of the companies delivering in this area have to run around 150 miles each time they bring a load this means it takes awhile, to make up for this more material is brought per load,
