B414 clutch
Phil Tibbetts
PostPosted: Fri Feb 22, 2013 1:18 pm    Post subject: B414 clutch Reply to specific post Reply with quote
Anyone know why the clutch pedal on a B414 gas will not go all the way down. When you push it it goes half way and stops. It acts like something is stuck. I bought this not running last fall and it has been too cold to work on it but I know this problem exists. The motor is not stuck and I plan to get it running when it warms up. I rebuilt the carb this winter. It also has an electric fuel pump but I don't know why as the engine driven fuel pump seems to be ok. I also have a 364 diesel and that also has an electric fuel pump same kind (Facet). Is this some sort of factory retro fit?
ben brown
PostPosted: Fri Feb 22, 2013 7:00 pm    Post subject: Re: B414 clutch Reply to specific post Reply with quote
they have a two stage clutch in them what the first stage that working is engine clutch when you hit stop hard spot half way down your hitting the second stage that release the pto it well be a lot harder to push it and you don't have to go far for it to release pto why electric fuel pump who know maybe it just started better
Phil Tibbetts
PostPosted: Fri Feb 22, 2013 8:47 pm    Post subject: Re: B414 clutch Reply to specific post Reply with quote
I know about 2 stage clutches but it is not possible to push the pedal beyond the first stage. I pushed as hard as I dared to without damaging anything.
JimB2
PostPosted: Sat Feb 23, 2013 5:40 pm    Post subject: Re: B414 clutch Reply to specific post Reply with quote
PTO clutch is stuck to pressure plate and flywheel.
JimB
Phil Tibbetts
PostPosted: Sat Feb 23, 2013 6:09 pm    Post subject: Re: B414 clutch Reply to specific post Reply with quote
Is there any way to free it up without breaking the tractor in half?
