| Author |
Message |
Josh Blackburn Regular
Posted: Sun Feb 24, 2013 6:34 pm Post subject: More Stroker Cranks |
Heres some JD cranks in the works...
| Back to top |
Posted: Sun Feb 24, 2013 6:45 pm Post subject: Re: More Stroker Cranks |
some more
| Back to top |
MNJDG New User
Posted: Sun Feb 24, 2013 6:51 pm Post subject: Re: More Stroker Cranks |
How many hours do you end up with lets say a 9.25 stroke john deere crank? Seems to be big money difference from builder to builder. Not pointing fingers at anyone, just curious. |
| Back to top |
Posted: Sun Feb 24, 2013 7:08 pm Post subject: Re: More Stroker Cranks |
They all vary. By the time I balance the whole assembly and polish I could be pushing 25-35 hrs. Some take longer some take less. A lot of time and welding wire and heat go in to each one. |
| Back to top |
MNJDG New User
Posted: Sun Feb 24, 2013 7:26 pm Post subject: Re: More Stroker Cranks |
They actually are reasonably price most of the time, with that many hours into them. If done correctly and corners not cut. I received one that was so bend it trashed the bearings in half hour of run time. |
| Back to top |
2-banger Long Time User
Posted: Sun Feb 24, 2013 7:29 pm Post subject: Re: More Stroker Cranks |
you get it from merfield? the bad crank that is |
| Back to top |
clampdaddy Regular
Posted: Sun Feb 24, 2013 7:38 pm Post subject: Re: More Stroker Cranks |
Hey Josh, you got a number I can reach you at? I have a set of rockers I need cut and welded. |
| Back to top |
Posted: Mon Feb 25, 2013 10:52 am Post subject: Re: More Stroker Cranks |
9892775366 |
| Back to top |
FactoryFarmer Long Time User
Posted: Tue Feb 26, 2013 8:35 am Post subject: Re: More Stroker Cranks |
Looks good! I think I know who is making my next crank when I break this one. |
| Back to top |
just asking New User
Posted: Tue Feb 26, 2013 9:43 am Post subject: Re: More Stroker Cranks |
How do you balance it without the clutch and flywheel? |
| Back to top |
Posted: Tue Feb 26, 2013 5:08 pm Post subject: Re: More Stroker Cranks |
You bring the driver and flywheel or ship it. Cranks are balanced alone. Then I add flywheel and driver and balance as a unit. |
| Back to top |
wdjohn New User
Posted: Wed Mar 06, 2013 5:46 pm Post subject: Re: More Stroker Cranks |
josh do you do any farmall cranks |
| Back to top |
