Will a 60H power unit block fit onto a CA tractor?
Jack in NY
PostPosted: Mon Feb 25, 2013 12:01 pm    Post subject: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
I picked up (lucked into) an AC block at the
scrapyard the other day. The serial number on it
is CR 59315 PA. It lacks the pistons (has sleeves
& crankshaft) and cylinder head and all the little
stuff...
I also have a CA tractor with a hole in the side
of the (CE) engine block.
I haven"t taken the micrometer out yet (too cold!)
but rough measurement and looking through the
parts catalog makes me think I can make the two
into one.
I"ve rebuild both a BE and CE engine before so I
know there"ll always be little issues- I"m just
wondering if I"m missing something on the power
unit block that"ll come back to bite me...
Can anyone say if this will or won"t work?
Thanks!
David R Inman
PostPosted: Mon Feb 25, 2013 2:18 pm    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
I'm told there the same motor, just that the cr is from power units such as the 60H.
To my understanding it sould be the ideal replacement block for you.
So provided your rods, and pistons are good, a new set of rings and maybe bearings, and you should have everything to take two and make one.
Here's the back post where I was told CR=CE.
Untitled URL Link
Jerry Coulter
PostPosted: Mon Feb 25, 2013 4:43 pm    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
Also, the 60H and CA had the same governor speed whereas the B & C engines were slower.
Bob Bancroft
PostPosted: Mon Feb 25, 2013 6:08 pm    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
I can't tell you anything for sure. The only difference in the block I can think of is the power units, depending on application, may have had a spot machined for a fuel pump. That wouldn't matter as it could be easily covered.
Jerry Coulter
PostPosted: Tue Feb 26, 2013 5:50 am    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
Check to make certain that the 60H block is new enough to have the mounting holes for a generator bracket
McBride
PostPosted: Tue Feb 26, 2013 6:17 am    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
You can make most anything fit if you have enough money.
Jack in NY
PostPosted: Wed Feb 27, 2013 1:54 pm    Post subject: Re: Will a 60H power unit block fit onto a CA tractor? Reply to specific post Reply with quote
@David - Thanks! That was the link I was looking for- it's just hard to search through all the information on this site!
@Jerry - I was worried for a moment, but under a thick coat of grease and grime there are generator holes!
@Bob - There is an odd flat spot on the side that I haven't seen on other blocks, so that might be where the fuel pump went... I'm hoping to find power unit pictures just to see if that's the case...
@McBride - I spent all my money on torches, welders and scrap metal... they'll make it fit too!
