| Author |
Message |
Ed S. (IL) Tractor Expert
Joined: 20 Apr 2003 Posts: 2255 Location: The Middle West
Posted: Mon Feb 25, 2013 7:37 pm Post subject: Oops! Hooked up float charger backwards to 6V battery |
Went out to start the 8N tonight to position it ready to plow the predicted 6-8" of snow coming, and she was flat as a pancake. I wasn't paying attention when I pulled the float charger off, but I suspect I must have hooked it up backwards after the last time I ran the tractor. I wondered why it took so long to register a full charge (weeks).
The battery was showing -0.4volts... Don't know if I can bring it back or not, but I put the float charger back on the right way this time and will check it in the morning to see if the battery is taking a charge. I'm still 6volt positive ground...
I'm over 50 now. Does this count as a Senior Moment?
es |
| Back to top |
Royse Tractor Expert
Posted: Mon Feb 25, 2013 7:45 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
It just might!
Ask them for a senior discount if you have to buy a new battery!  |
| Back to top |
Bob Harvey Tractor Guru
Posted: Mon Feb 25, 2013 7:47 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Nope, no senior moment points. You are only a senior when the cashier at the supermarket says "thank-you sir". (there may be other markers) ;^) |
| Back to top |
Tom N MS Tractor Guru
Posted: Mon Feb 25, 2013 7:58 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Over 50 senior moment--Yes and it gets worse |
| Back to top |
Jimmyjack Long Time User
Posted: Mon Feb 25, 2013 8:26 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Most float chargers just maintain charge or charge a
very little, you might have to put a real charger on
it to bring it back. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50675 Location: Lake of the Ozarks area of MO
Posted: Mon Feb 25, 2013 9:06 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Only way you might and it is a slim chance to save that battery is to discharge it all the way and then some then slow charge it, but even then not a good chance. As for you age my son has marked the battery chargers so he can remember that red is + and black is - and he is in his 20s |
| Back to top |
GB in MT. Tractor Guru
Joined: 17 Jun 2007 Posts: 5688 Location: Seeley Lake, Mt. (Home of "Hermie the 2N")
Posted: Tue Feb 26, 2013 3:22 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
| Ed S. (IL) wrote: | (quoted from post at 21:37:50 02/25/13) Went out to start the 8N tonight to position it ready to plow the predicted 6-8" of snow coming, and she was flat as a pancake. I wasn't paying attention when I pulled the float charger off, but I suspect I must have hooked it up backwards after the last time I ran the tractor. I wondered why it took so long to register a full charge (weeks).
es |
ED;
NOT, a senior moment!!!! BUT, .....now I understand the statement on yer T-shirt!!!!!
Gary |
| Back to top |
Posted: Tue Feb 26, 2013 5:40 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Hey, I resemble that remark! (ouch!) I did get asked the other day if I was eligible for a senior discount... The (obviously older) man ahead of me said he was thankful they didn't ask him!
Just came in from morning chores and the battery now shows +0.46 volts (on the float charger). Will keep an eye on it - maybe it will come back.
es |
| Back to top |
Bob Purinton Regular
Posted: Tue Feb 26, 2013 5:55 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
They say that the mind is the first thing to go...
It's the second thing that scares me...whatever that is.  |
| Back to top |
Posted: Tue Feb 26, 2013 6:08 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Ed;
Not too sure about this, BUT, I think you may be better off, using a reg. battery charger, with 2amp. charge. Slow charge at 2Amps, would bring the batt, charge faster and keep the plates warmer....JMHO.
Even if it does charge up to full cap, being drawn down so low, may hinder the battery's 'cranking' Amps!!????
BTW...the old Exide battery that you saw on Hermie when you were here, is going on 7yrs in age, and STILL is perkin' like a NEW batt.
Who would'a thunk it?????
Gary |
| Back to top |
Posted: Tue Feb 26, 2013 7:01 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
I might go swap chargers then, although my normal charger doesn't have the ability to set the charge rate - I was kind of afraid of over charging and blowing up the battery...
es |
| Back to top |
Posted: Tue Feb 26, 2013 7:12 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Don't think ya have to worry about blowing up the battery, if the batt. caps have vents, and your charger is not any more than 10 amps!!
If you are worried, just charge with the reg. charger, until it shows 3/4 charge,....then shift back to the trickle charger, to top off the charge.
Then watch yer amp guage, on the "N" to make sure the VR is shutting down at full charge. (Check the voltage at the batt.....key off!!)
Gary |
| Back to top |
teddy52food Tractor Guru
Posted: Tue Feb 26, 2013 7:32 am Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Mind is the 2nd to go & I forgot what the 1st is. |
| Back to top |
tracman Regular
Joined: 16 Feb 2010 Posts: 127 Location: Black Creek, BC
Posted: Tue Feb 26, 2013 1:02 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
Ed, the float charger my be going flat as well. The dead battery may too much of a load. You may want to try a higher current (10 Amps) type charger for few minutes to get some volage back on the your plates. Just remeber safety first with eye protection and no sparking at the battery because of the hydrgen gas given off during charging. At my age I have senior hours. |
| Back to top |
JoeN'Mo Regular
Posted: Tue Feb 26, 2013 1:06 pm Post subject: Re: Oops! Hooked up float charger backwards to 6V battery |
The thing that bothers me is the guys in the nnalert commercials are younger than I am !!!
Over The Hill Joe |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
