swapping engines
porsche
PostPosted: Wed Feb 27, 2013 10:32 am    Post subject: swapping engines Reply to specific post Reply with quote
I have an International 424 with a IH-C146 gas engine. Does anyone out there know if it will bolt into an Farmall C tractor? Also, if a AC D14 or 15 engine will bolt into an AC C tractor ? Thanks.
Dick L
PostPosted: Wed Feb 27, 2013 12:59 pm    Post subject: Re: swapping engines Reply to specific post Reply with quote
The farmall won't but the D-14 /D-15 will.
You need to use the C flywheel though.
Bill MO.
PostPosted: Fri Mar 01, 2013 7:53 am    Post subject: Re: swapping engines Reply to specific post Reply with quote
As Dick said Yes, but besides using the C flywheel:
The bolt holes in the radiator mount need to be drilled out for the 5/8" bolts on the D10/12/14/15 engine.
The oil fill hole in the hood is in a different position.
The C fan needs to be used.
The air filter will not fit. (I fabricated a tube that comes out of the hood with a K&N filter on it.)
You will need to mount the D.. water temp guage some place.
The muffler hole needs to be moved an inch or so to the left.
Bill MO.
PostPosted: Fri Mar 01, 2013 8:11 am    Post subject: Re: swapping engines Reply to specific post Reply with quote
Low B with D14 engine
porsche
PostPosted: Fri Mar 01, 2013 9:45 am    Post subject: Re: swapping engines Reply to specific post Reply with quote
Thanks Bill and Dick for your input. I am working on building a pulling tractor for my nephew. I want to use one of these tractors. Just wanted to see what was possible. Thanks again
