| Author |
Message |
Josh Russell New User
Posted: Wed Feb 27, 2013 5:03 pm Post subject: Rollamatic |
I am looking for a rollamatic narrow front end for my John Deere 3010 and a guy gave me a rollamatic from under a John Deere 50 and said it would work . My 3010 has a wide front under it now so I have nothing to compare it with . If any one has any input for me on this I would greatly appreciate it .
Josh |
| Back to top |
long green line man Regular
Posted: Wed Feb 27, 2013 6:40 pm Post subject: Re: Rollamatic |
Roll-O-Matic from a 50 is very lite duty , small spindles & bearings, 3 bolt plate on spindle arm attach.. I'd look for a HD. 4 bolt plate, same spindle & bearing as your wide front... |
| Back to top |
Posted: Thu Feb 28, 2013 1:19 pm Post subject: Re: Rollamatic |
Ok good to know thank you for your response . |
| Back to top |
jwuertz Regular
Posted: Fri Mar 01, 2013 3:41 am Post subject: Re: Rollamatic |
would one from a jd 60 work? |
| Back to top |
Posted: Fri Mar 01, 2013 6:01 pm Post subject: Re: Rollamatic |
I am not sure about that. It might. |
| Back to top |
Posted: Sat Mar 02, 2013 10:29 am Post subject: Re: Rollamatic |
One from 60 should be very similar , very early model 60 & late A with split pedestal are slightly dif. Late model 20 series (new gen) tractors used a improved ex.HD Roll-o-Matic. Id. by 3/8 bolts in plate att. spindle arm... |
| Back to top |
Posted: Sat Mar 02, 2013 2:09 pm Post subject: Re: Rollamatic |
Ok good to know . Thanks again for the information . Very helpfull. |
| Back to top |
jwuertz Regular
Posted: Sat Mar 02, 2013 3:52 pm Post subject: Re: Rollamatic |
On my 54 jd60 it has the 4 bolt square pattern
I,m not sure of the measurements though. what are they on your 3010? |
| Back to top |
Posted: Sat Mar 02, 2013 6:26 pm Post subject: Re: Rollamatic |
My 3010 has an after market wide front end that is different than the actual john deeres . It is a really poorly made front end and it keeps breaking spindles were the tie rod connects to them . I am tired of fixing it and would like to take it back to original or at least a john deere front end . |
| Back to top |
tomstractorsandtoys1 Long Time User
Posted: Sun Mar 03, 2013 11:55 am Post subject: Re: Rollamatic |
I maybe late to post on this but when you go to put your rollomatic on make sure you get the correct length bolts,they are 2 1/4 (I maybe wrong)if you use the wrong bolts it will mess the seal up in the bottom of the steering motor and you will not know it untill it starts leaking. |
| Back to top |
Posted: Mon Mar 04, 2013 4:03 pm Post subject: Re: Rollamatic |
No you are not to late . I did not know that. Any information can always be useful. Thanks for the reply. |
| Back to top |
Plant Doc New User
Posted: Wed Mar 06, 2013 3:34 am Post subject: Re: Rollamatic |
I have a rollamatic from my 3010 that I converted to a wide front. I am willing to part with it for the cost of the freight. I am in NJ if interested. |
| Back to top |
Posted: Wed Mar 06, 2013 2:56 pm Post subject: Re: Rollamatic |
Thank you very much for the offer but I have located a front end a few miles from me that I am going to get after it gets warmer. |
| Back to top |
