| Author |
Message |
hillaagsa New User
Posted: Sat Mar 02, 2013 5:51 pm Post subject: JD A flywheel nut removal |
Hello I'm working on a later style JD A. We are trying to remove the flywheel off and I already have the two bolts out. How do you remove the big tin nut from the shaft? Is it threaded? and if it is and has to be turned what is the best way to hold the flywheel from spinning since the rods and everything else are disconnected.
Thanks |
| Back to top |
Dennis Andres Regular
Posted: Sat Mar 02, 2013 6:13 pm Post subject: Re: JD A flywheel nut removal |
The nut is threaded but if you look there is a groove on the shaft and the nut is locked by using a punch to bend a tab in the groove. You must take a small chisel and drive it under the tang and bend it up out of the groove then you can turn the large nut counterclockwise. |
| Back to top |
clampdaddy Regular
Posted: Sat Mar 02, 2013 6:42 pm Post subject: Re: JD A flywheel nut removal |
To keep it the flywheel from turning you could hook a high lift jack into one of the holes on the flywheel or put a rope through a hole and tie it off to the rear axle. |
| Back to top |
hillaagsa New User
Posted: Sat Mar 02, 2013 11:28 pm Post subject: Re: JD A flywheel nut removal |
Thank you guys for all the help. I actually got the flywheel off
tonight with no problem at all after that. Thank you |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
