9N alternator
Gary Schones
PostPosted: Sun Mar 03, 2013 9:13 am    Post subject: 9N alternator Reply to specific post Reply with quote
I have had a problem with my 12 volt charging system since I tried to jump my truck last year. It could be a coincidence but my battery charges and I use the tractor for a while and the battery is dead. I replaced the alternator and when I put a tester on the battery I get a scrambled read out while it is running. The alternator is currently hooked up with a one wire system which is the way it came. I am wondering if I need to change to a 3 wire. Any help s appreciated. Thanks, Gary
HCooke
PostPosted: Sun Mar 03, 2013 9:20 am    Post subject: Re: 9N alternator Reply to specific post Reply with quote
" when I put a tester on the battery I get a scrambled read out while it is running."
A digital VOM will not work with these old ,achines. Too much noise from the ignition. You need to get an analog VOM.
old
PostPosted: Sun Mar 03, 2013 10:04 am    Post subject: Re: 9N alternator Reply to specific post Reply with quote
Yep many of the digital meters do odd things around engines. I am lucky my meter works just fine. As for 1 wire or 3 wire the 3 wire is far better and does not need the high RPM to start charging as the 1 wire does. You do know most auto part stores with test your alternator for free don't you??
Gary Schones
PostPosted: Sun Mar 03, 2013 11:58 am    Post subject: Re: 9N alternator Reply to specific post Reply with quote
I took the alternator to Orileys and they said that it was bad. I bought another one but still having some charging issues
old
PostPosted: Sun Mar 03, 2013 12:13 pm    Post subject: Re: 9N alternator Reply to specific post Reply with quote
Ya if it is a one wire that is where the problem is. Take it back and get a simple 3 wire like for a 1980 Chev pick up on AC not power any thing. At O'Reilly's it should cost around $45 and that is with a life time warranty. Been using those for years now and if it does go bad you take it back and they hand you a new one for free.
souNdguy
PostPosted: Mon Mar 04, 2013 11:37 am    Post subject: Re: 9N alternator Reply to specific post Reply with quote
what issues?
