Spraying herbicide.
Goto page 1, 2  Next
Darryl 2Ms
PostPosted: Sun Mar 03, 2013 6:16 pm    Post subject: Spraying herbicide. Reply to specific post Reply with quote
Hi! Two dumbells here! Father and son team thinking of planting silage corn. Just wondering how much 2,4,D to use per acre. Trying to figure costs etc. before jumping in to this. Been doing hay for a few years, now expanindg into beefers, and pigs.Hey, someone has to take the plunge! Or where is our food gonna come from? LOL Thanks in advance guys... Darryl
Aaron SEIA
PostPosted: Sun Mar 03, 2013 6:56 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
I'd start by reading the label. 2,4-D on emerged corn is a tricky business. You can mess with the growing point and make the stalk extremely brittle. Your better bet would be to buy some Rounduo ready corn. Generic Roundup can be bought fairly cheap and doesn't need any licensing to buy. Ideally you'd put down something pre emerge like Harness Extra, or Dual and come back if needed with a post treatment for any escape broadleaf plants. If you have a local Coop or agronomy store where you'd buy seed, fertilizer, etc. They will have a good plan for weed control in your area and tell you what licensing you need to have to buy and apply.
AaronSEIA
paul
PostPosted: Sun Mar 03, 2013 9:35 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
Another person not answering your question, but some version of dicamba can be a much better choice for about the same money. Banval, Clarity, and many others, it is off patent now so many are making it.
http://ipm.illinois.edu/ifvn/volume16/herbicides_containing_dicamba.pdf
I really like Status, it is a granular, it has safeners in it so you can spray it on taller corn. Really gets the broadleaves.
As for 2,4D, it seems less effective any more. Depends on if you are talking the ester or amine, and what formulation. Hard to give an exact answer without knowing what brand of the stuff you are going to use.
In general I got nervious at a pint an acre but it didn't kill so well at 1/2 pint, and the corn can't be more than the 5th leaf showing or you will hurt the corn.
http://www.cdms.net/ldat/ld44N002.pdf
Paul
LAA
PostPosted: Mon Mar 04, 2013 5:33 am    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
No till or minimum till? how clean are your fields now? 2-4-D alone never did the whole job for me post emergence and you have to get on it when the corn is 4-6 inches tall unless you have drop nozzles, even then I would not do it in my area due to the high average temperature. I have way better luck for silage corn with RR variety and spray round up one time at 12 inches tall, thats after no till in ryegrass/clover stubble with no pre-plant applications. 3 trips across the field and the 3rd one is with the chopper.
rrlund
PostPosted: Mon Mar 04, 2013 6:46 am    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
You could just go with Roundup Ready and spray one quart of Roundup per acre. No need for the 2,4d if you do that.
All Powershift !!
PostPosted: Mon Mar 04, 2013 10:55 am    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
If you are planning on planting a conventional corn hy. (a non GMO hybrid) try a brown mid-rib silage hy. makes a sweeter more digestable silage, & good ear corn for hogs too.. You'll probably need a grass killer along with the (dicamba) 2-4-d, Banvel etc. Try Accent , worked good on postemerge foxtail etc. for me...no carry over like attrazine based herbicide's.......
Karl 6030
PostPosted: Mon Mar 04, 2013 5:20 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
2 4d is not that big of deal poasting over the top if the corn is 2ft tall or bigger put on drops to keep it out of the whirl lv 6 is around 28.00 dollars a gallon and run about 6 oz to the acre depending on weed size and run 15 gallon to the acre on water you will have great kill any question give me a call 1 618 926 1286.
Iowa Jim
PostPosted: Mon Mar 04, 2013 5:22 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
Need to add a residual to a Roundup Ready system to get the best weed control. Spranying only Glyphosate is the reason we are now fighting resistant Palmer Amaranth, Marestail, and other weeds.
rrlund
PostPosted: Mon Mar 04, 2013 5:43 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
Ya I know. I use Prowl and Atrazine pre emerge and seldom even have to clean up with Roundup,but if it's this guy's first time,it's best to make it simple.
Nice
PostPosted: Tue Mar 05, 2013 7:03 am    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
Go to your local fertilizer service/co-op and talk to them. The manager there will set down with you and help come up with a plan and give you estimated costs. If you don"t already have a fertilizer service that you go through for your hay, then you definately want to get in touch with one. They offer services that a corn farmer can"t do without, such as soil sampling, custom fertilizer/spraying, and good agronomic advice. Not sure how many acres you"re thinking, but even 20 corn acres adds up to a decent amount of inputs, and they probably don"t get many "new" customers, so they should be interested in your business and give you good service.
Darryl 2Ms
PostPosted: Tue Mar 05, 2013 4:23 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
thanks! sounds like good advice. just looking to get our feet wet this year. maybe 5-10 acres. Have to try. If us New guys don't who will? lol
Darryl 2Ms
PostPosted: Tue Mar 05, 2013 4:25 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
thanks Karl. I always get good input from everyone here on YT. thanks again
Darryl 2Ms
PostPosted: Tue Mar 05, 2013 4:32 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
thanks for your input. I was thinking of a sweet corn or anything that is a small round kernel, because I'm planting with a grain drill! Oh no! I got mixed feedback on THAT here on YT. But thats all I have for this year... An old I/H Mcormick 7x13. And they recommend a small round seed kernel for silage cor. This is all new to me but I gotta try!Buying feed is getting expensive and I have a hammermill soooo....
Darryl 2Ms
PostPosted: Tue Mar 05, 2013 4:37 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
sounds good. I had just figured 2,4,d because it's cheap. Guess I have to talk to my extension agent. It's confusing at first with so many chemical choices, but we'll figure it out. Hope it's not too late in the season...
Darryl 2Ms
PostPosted: Tue Mar 05, 2013 4:40 pm    Post subject: Re: Spraying herbicide. Reply to specific post Reply with quote
thanks Jim. I see i have more research to do. Don't want to contribute to weeds getting more resistant to herbicides. Time for my local agent i guess thanks
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
