409 farmall clutch
iH welker
PostPosted: Mon Mar 04, 2013 3:28 pm    Post subject: 409 farmall clutch Reply to specific post Reply with quote
I have a 11" flywheel off of a M what clutch and pressure plate will work on this motor?
ss409
PostPosted: Tue Mar 05, 2013 9:14 am    Post subject: Re: 409 farmall clutch Reply to specific post Reply with quote
super m, super mta, 400 and 450 flywheel, super m clutch disk, 966 pressure plate.
iH welker
PostPosted: Tue Mar 05, 2013 5:56 pm    Post subject: Re: 409 farmall clutch Reply to specific post Reply with quote
Thanks I was told by Denny's a 11" 6 button disc and a heavy duty pressure plate is all I needed
ss409
PostPosted: Wed Mar 06, 2013 8:27 am    Post subject: Re: 409 farmall clutch Reply to specific post Reply with quote
what i mentioned worked real good. on a M-SM, you should remove the live pto drive hub on the 966 pressure plate, you can find 6 button disks for SM at a clutch shop, the pressure plate can be ordered off this site. take your flywheel, disk and pressure plate to the shop n have it all dialed in n holds pretty good for not alot of money.
IHSMOKE
PostPosted: Wed Mar 06, 2013 4:30 pm    Post subject: Re: 409 farmall clutch Reply to specific post Reply with quote
all of the above is what i got in my m-ta ... use a flywheel from a super m - a 450 its 12 inch ....but i use a 986 pressure plate those were hydro asst clutches ...higher spring pressure on the plate gives leg a work out ... call ed at Leamans tractor parts in pa he can hep ya get beefy ...my clutch has a 1566 center in it for the damper on it
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
