SOS to 5 speed conversion with Diesel Which flywheel?
Frazier2cyl
PostPosted: Tue Mar 05, 2013 6:39 pm    Post subject: SOS to 5 speed conversion with Diesel Which flywheel? Reply to specific post Reply with quote
Probably about to swap out a non working SOS in a 971 diesel. I have a 850 tractor as a donor with 5 speed. My question do I need to find a diesel flywheel for a 4/5 speed trans to make this happen.
Texas!
PostPosted: Tue Mar 05, 2013 7:09 pm    Post subject: Re: SOS to 5 speed conversion with Diesel Which flywheel? Reply to specific post Reply with quote
Use the flywheel and the engine/transmission spacer plate from the 850.
Ultradog MN
PostPosted: Wed Mar 06, 2013 3:56 am    Post subject: Re: SOS to 5 speed conversion with Diesel Which flywheel? Reply to specific post Reply with quote
Gas or diesel makes not difference on the flywheel. You must use the flywheel that came with the tranny. You also must use the block plate that came with the tranny.
Wm. Neal
PostPosted: Wed Mar 06, 2013 2:29 pm    Post subject: Re: SOS to 5 speed conversion with Diesel Which flywheel? Reply to specific post Reply with quote
If you are changing from a gas to a diesel I think you need to change the ring gear; there's a different number of teeth for gas vs. diesel. The ring gear is "heat shrunk" onto flywheel; I changed one with heat from an acet. torch in one spot only.
shaun wallace
PostPosted: Wed Mar 06, 2013 5:55 pm    Post subject: Re: SOS to 5 speed conversion with Diesel Which flywheel? Reply to specific post Reply with quote
The connector tube between trans and r/a pinion has different number of splines.
