farmall b /bolt torque
g seifried
PostPosted: Wed Mar 06, 2013 12:11 pm    Post subject: farmall b /bolt torque Reply to specific post Reply with quote
does anyone know what the torque values are on the head and rod bolts for this tractor motor
Edchainsaw
PostPosted: Wed Mar 06, 2013 12:24 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
according to the IH shop manual the rods are to be 40ft/#
head 65ft/#
IT manual agrees on head but says 40-45 on rods
old
PostPosted: Wed Mar 06, 2013 12:45 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
From what I have been told by guys on here 65 for the head is the old number and the new number is 85 ft/lbs
Edchainsaw
PostPosted: Wed Mar 06, 2013 12:47 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
i would think that would be wise myself.... but the book dont take in "learned wisdom" lol
old
PostPosted: Wed Mar 06, 2013 1:28 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
Yep when I did my BA I used the old 65ft/lbs and it has been ok but was told I should have used 85 but since it isn't broken I have not fixed it LOL. But I also did this tractor old school as in how a farmer back in the 40s may have ad to get by as in no new gaskets and as much used stuff as I could get by with. I did use a used head gasket but used 6 coats of Aluminum paint on the gasket and head and block ad the last coat was done wet so it sort of glued the head on
teddy52food
PostPosted: Wed Mar 06, 2013 1:34 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
Torque the rods to 40 & if the cotter key doesn't go in just turn it enough to do so. Heads should be 80. I usually go to 75 in 3 or 4 steps then go to 80 after a few heat cycles.
Red Dave
PostPosted: Wed Mar 06, 2013 2:39 pm    Post subject: Re: farmall b /bolt torque Reply to specific post Reply with quote
Head bolts are 80 ft/lbs. Read your head gasket, it probably calls for Sealer to be used and retorque after the engine has been warmed up.
