| Author |
Message |
todd 765 Guest
Posted: Wed Mar 06, 2013 5:41 pm Post subject: Farmall B |
Bringing back to life tractor been sitting for several years. Finally got it to run but have to have the carborator choke 1/4 pulled for it to run. Any ideas? |
| Back to top |
teddy52food Tractor Guru
Posted: Wed Mar 06, 2013 6:03 pm Post subject: Re: Farmall B |
Clean the carb. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50680 Location: Lake of the Ozarks area of MO
Posted: Wed Mar 06, 2013 6:28 pm Post subject: Re: Farmall B |
That could be a few things wrong. Poor spark will cause that. You need a blue/white spark that jumps a 1/4 inch gap or more. #2 you need a good steady flow of gas out the carb drain plug for a few minutes. #3 you need a clean air cleaner with the correct amount of oil in it. #4 you need enough compression to pull the fuel into the cylinders as it should. Any one of those not being as it should be will cause that problem |
| Back to top |
LMack Long Time User
Posted: Wed Mar 06, 2013 7:32 pm Post subject: Re: Farmall B |
Let it run for a while as well as all the other suggestions. You may have to drain the fuel bowl on the carb sevral times to get a good flow of fuel. A good cleaning will do the job, but it may just need a good flushing out. Be sure your fuel is fresh. Look for leaks in the intake manifold. A leak will make it run lean. |
| Back to top |
todd765 Guest
Posted: Thu Mar 07, 2013 8:30 am Post subject: Re: Farmall B |
Manifold is new, Carb has been cleaned, sediament bowl assemble is new. Have check flow out of carborator. I have installed the carb kit and with kit replaced the seal on butterfly. Any more ideas problem still their. Sparkplug,wires,cap, points, condensor and rotor new. |
| Back to top |
mkirsch Tractor Guru
Posted: Thu Mar 07, 2013 11:06 am Post subject: Re: Farmall B |
Manifold leak? Maybe it's leaking around the carb/manifold flange? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
