compression test
rrman61
PostPosted: Thu Mar 07, 2013 7:57 am    Post subject: compression test Reply to specific post Reply with quote
how would i do a compression test on a 1650 diesel?
dboll
PostPosted: Thu Mar 07, 2013 8:13 am    Post subject: Re: compression test Reply to specific post Reply with quote
with an adapter in the injector hole, you can take an old injector and make one
J. Schwiebert
PostPosted: Thu Mar 07, 2013 12:02 pm    Post subject: Re: compression test Reply to specific post Reply with quote
Direct injection or Lanova head?
rrman61
PostPosted: Thu Mar 07, 2013 6:45 pm    Post subject: Re: compression test Reply to specific post Reply with quote
Direct injection I think.Injectors on outside of engine ,2 bolts hold them on.Serial no.167-559-452,model no:265-2298.Shows as 1965 model.Can someone explain the difference between the 2 different head types and how to identify them?
J. Schwiebert
PostPosted: Thu Mar 07, 2013 6:56 pm    Post subject: Re: compression test Reply to specific post Reply with quote
You have an early 1650. It is not direct injection. Do you think you are low on compression on one cylinder or all of them? A poor mans compression test. Remove the exhaust manifold and see which exhaust ports the white smoke comes out of.
rrman61
PostPosted: Thu Mar 07, 2013 8:39 pm    Post subject: Re: compression test Reply to specific post Reply with quote
Thanks ,I'll try that j.Will change my fuel filters first to rule that out.Its running rough.I cracked open all the lines one at a time while running.Pretty sure its not the injectors.Just rebuilt the injector pump too.Bought the tractor not running[injector pump needed rebuilding].Emits white smoke when just started,not so much after it warms up.
i
