Ok, I removed starter on H for a general cleanup and lube...had to remove mounting bracket to remove starter....not a big deal. Took a wire brush to all the teeth on the ring gear. Put back together and tractor spun over super fast (with plugs in)...that's great. Once I got it running with new condenser, now the Bendix seems to be still engaged after tractor starts. The Bendix is in great shape, now super lubed, and slip clutch on end works fine. I seems like the geometry has changed after cleaning up bracket and place where it mounts. Perhaps the whole starter moved towards center of tractor after things were cleaned up. There wasn't any gunk behind the starting bracket on the side of tranny. Well, the Bendix seems to have moved so starter gear is continuously engaged with flywheel teeth. The problem is, the mounting bracket has the integral snout that covers the gears that a guy wants to look at and see the problem.
