in-too-deep
- Location
- 56676
Hello all,
Late 1070 only getting 1800 psi at the remotes at idle and 1850 psi at 2k rpm.
I'd like to see 2250 psi for lifting a discbine.
New pump is on the way, but I'd like to try shimming the relief valve first. Is there any way to get that relief plug out without removing the entire valve? Those 2 bolts on top are going to be very difficult if not impossible without removing the fuel tank, which I'd like to avoid. I have a service manual, but I thought I'd check here for tips and tricks.
Thank you.
Thank you.
