I just split my tractor today. A few years ago, I did the pan gasket. It's had a slow drip from the transmission since I got it, but I noticed recently a pretty steady drip of what looked like engine oil. So either the rear main, or the pain gasket has failed again.
Overall the split went pretty good without any help, aside from a broken fuel line.
I have questions about parts needed. I noticed several different clutch kits on this site. I counted 10 splines on both shafts coming out of the gearbox. The clutch looks like this one:
https://www.yesterdaystractors.com/Massey-Ferguson-135_Clutch-Kit-Dual-Coarse-Spline_12121400.html
However it says not for Deluxe models, and I think mine is Deluxe. It has 1964 stamped on the oil pan and the serial number is behind the air cleaner, so I think it's a first year US 135.
Is there something I can measure to make sure I order the right kit?
Parts I know I need so far:
new clutch kit
oem rear main rope seal
(2) seals for trans input shaft
paper gasket for trans input shaft
gasket between gearbox and rearend
gasket for break pedal mounts? 3 gaskets came out, not sure if these are required or not.
This post was edited by jtxn on 10/26/2023 at 01:54 pm.
new clutch kit
