135 front hydraulic pump yes or no
I have a 135 with continental engine. I'm considering putting a front pump to run a hydraulic top link on a set of forks. I cant find much online about it but a few posts says that I can snap the crankshaft and suggest that the continentals have a weak point there. What advice can you give for this idea. I know I would need a different pulley to connect the drive shaft to but not totally sure what else to consider or if its even safe to do it.
This is the parts you need
Unless you can find a used bracket to mount the pump you need to make one, or have it made
