1650 hydraulic pressure checking
CP1
The plug to check the pressure by your left foot is tight, so put a gauge in the coupler at the rear. Seems to have pressure at the hoses all the time. Lower at idle, but high idle is about 1800. Stays pressure when the tractor is shut off. This normal?
Yes, Olivers are constant pressure on the remotes. You need the lever release couplers, wiggling the levers is good excersize for your forearms but that's all.
That is an open center system. It will show some pressure when running with no hydraulic load just from circulating the fluid. Mine is at 200 psi. Working the levers in both directions should relieve it.
