1850/1950 two speed hydra drive??
mogman
Are the two speed hydra drives the same for the 1850 and 1950 the same unit?
I have a hydra drive that came attached to a 4-53 block and I have a 1850 that has a vibration in high drive and was thinking of going through the spare in case or when the one in the 1850 gets worse.
Also is the sprag clutch still available??
The sprags were still available last I checked but they're deep pocket $$. Yes, they should interchange. There are minor differences in the hydra power, Chris talks about them in his latest videos:
They do show the same input shaft numbers with the same serial number split so I am probably OK although I don't have a clue what the serial number was for the donor drive, although with some more parts investigation I may be able to tell what serial number plit it is.
