Fritz Maurer
May be missing this part in filter
That's strange that my '41 9n gas 40# cold and about 20# hot. Bearing clearances,spring tension on relief valve have a lot to do with oil pressure. I don't want to start an "oil battle",but I use 15W40.The oil pump in the early 1950 tractor have a thinner gear size than tractors with a S/N after 247571. In the early tractors there is less volume flow rate and lower oil pressures than with the later model 8Ns. (Expected)
The correct oil gauge for front mount distributor is 9N 9273A which is 0-50psi gauge. The 0-80 psi gauges used in later model 8Ns are not as accurate with the lower pressures, and may not read correct.
You may want to vent the line at the gauge as well.
I got thinking the same thought so instead i plugged the t going to cartridge bingo 25psi. the canaster has been replaced by a new aftermarket one the brass fitting was not a restrictive one. I ordered a restrictive one lets see what happens ill let you know !This might be a long-shot suggestion, but how long did you run it for when you blocked the governor line? If some of the oil drained from the filter can when you took off and blocked the line at the governor, it would a few minutes to fill the filter cavity, displace the air, and start pressurizing it. Similar to if you don't pre-fill the filter cavity on a tractor with a cannister type of filter: It takes a little longer for the oil pressure to build up. Think of it like the bladder tank for a well system in your house: You can tell when your bladder's gone and the tank is completely full of water, because it'll pressurize instantly (what you want, in the case of your oil filter). When your well tank is working properly with an air cavity above the bladder it takes longer to build pressure.
Maybe try running it for at least 5-10 minutes or so with the governor line blocked and see if it changes?
yes they can i used smoke machine also vacuum pulled -30psi its all goodI believe the pickup tube solder joint can break, causing variable suction results. Also may need priming, then other start ups it doesnt.The screen on the drain plug, if intact, can "hold" it, and keep it from falling out. Need to drain the oil and put fingers on it to tell if its loose.
This pickup tube fell out as I dropped the jack.
I will i hopeing i found problem .Be sure to post the end of the story please.
ok after blocking off t and having good 25psi i ordered restriction fitting installed ran 10 min ran out of gas . put fuel in tank started walked away put gas can away came back 0 oil pressure i Quit this will have to weight till fall!!!Be sure to post the end of the story please.
Pretty sure the gear didn't come loose from the oil pump shaft - the shaft has a flat that the gear has to fit into - I can't imagine any way that could slip unless the new gear hole was completely round and didn't have a matching flat cut in in (not likely). With the oil line removed from the oil guage do you see any oil coming out of the line?i will find a stock replacement. But now with filter line plugged only line to guage i lost all pressure have feeling junk turkey made oil pump must have took a crap brass fitting did not fit housing to thick to press in machine shop got the correct one. Probley drive gear came loose from shaft !Just guessing
thats tomorrow have other project's todayPretty sure the gear didn't come loose from the oil pump shaft - the shaft has a flat that the gear has to fit into - I can't imagine any way that could slip unless the new gear hole was completely round and didn't have a matching flat cut in in (not likely). With the oil line removed from the oil guage do you see any oil coming out of the line?
