Case930ck
I bought my John Deere B a year ago for $800. It was rebuilt around 1980, painted pretty near 2000 and has seen little use since rebuild, never parked outside. I started the 6 mile drive home in perfect running condition. Half way home the points fouled and we pulled it the rest of the way. It ran pretty good after that except for a few times having no power pulling a heavy load. I drove it a mile to a garden, plowed it, then drove home. after that it plowed snow and would start first crank, no choke in -15 degree weather. No problems. This spring I drove 1/2 mile down the road with a full load of manure in 4th gear then turned around and hardly made it back in 1st. It has sat in the garage all summer. An old timer from church came and helped me time it to 25' over. Now I am trying to get the carburetor set. It will die right away with the settings I read in an A manual. It will run with both needles 3/4 to full, but it blows black smoke enough to fill a garage and get yelled at by the mom. sometimes the settings I have is lacking fuel and sometimes its backfiring from too much. It runs differently every time I start it and changes as it's running. The other problem is that something is out of balance. My dad and I made sure the flywheel and belt pully were 180' off. Different settings on the carburetor makes the steering shake to the point its a pain to hold on. Some settings it hardly vibrates, but the tractor doesn't run well. It has vibrated to the point the hole in the column is an 1/8 too big in diameter.
If you can make sense of this and think of a solution, please let me know.
Thank you, Oliver.
Thank you, Oliver.
