northerner05
Hi all,
I've got a 1950 MH30 with a stuck clutch. I don't have much details about its history before it came to me about a year ago. Been working on trying to free it using the methods described in the forum, but no luck yet.
My question is about any inspection plates or access to the clutch/flywheel other than pulling the starter? There are no obvious plates or plugs in the bell housing that give access. There is what appears to be some sort of small drain at the bottom, but barely big enough to fit a straw from an aerosol can. I can't tell if the clutch is stuck due to rust or oil from a rear main leak, or a combination of the 2. Not interested in splitting the engine for this fix.
If pulling the starter would be the only practical way to get some sort of access, does pulling the starter give sufficient access to the clutch/flywheel contact?
Tractor is 74 years old at the end of the month (casted birthdate indicates 30 September 1950). The engine runs great and it drives well. Great machine.
Thank you in advance!
