bluebulldozer123
1952 ford 8n side mount distributor 6 volt> Currently will not start sometimes it does start and runs for a few minutes then cuts off like no gas but it has gas and rebuilt carb flows great out the drain plug right after it stops running. I jumped the switch and nothing there to help , amp meter moves about 1/8 in with each revolution of the engine, grounded plug check reveals no spark, points set at 025 and are opening and closing. Changed points and it was worse only ran for a minute or so when and if it cranks, wires all look great and are fairly new I cleaned all connections . Coil got hot a couple times when i was testing, 6 volt constant at the coil. I am thinking the distributor is bad but I do not know how to confirm that. HELP!!!!!!!!!!!!! PLEASE
