Whistlin10Speed
I’ve got a 53 jubilee that has got me stumped, the other day I went to bush hog and it fired right up as usual but then just died all of a sudden after just a few minutes, it cranked for a while and finally restarted, then it mowed for 15 minutes and died again. This happened a few more times and it did not want to start after it would die, so I finally got it going again and just parked it.
Fast forward 5 days I thought maybe it had something in the fuel so I drained the gas, put in 5 gallons of non-ethanol fuel and some carb cleaner additive in case the carb got gunked up. It fired right up and ran like a scalded dog for about 2 hours bush hogging, then I parked to talk to my neighbor and let it idle for roughly 10 minutes and then just died out of nowhere. It will not start, just cranks and cranks and cranks. It is getting fuel, the fuel inlet screen is clear of any debris. The following parts are new with less than 30 hours on them: Coil, spark plugs, plug wires, battery, carburetor, solenoid, terminal block, wiring, and starting button.
Could this be distributor cap/ rotor related? I can’t think of what it could possibly be as everything else is new and that’s the only thing that hasn’t been changed. It all worked flawlessly all of last summer/ fall until now.
Any advice is welcomed and appreciated, thanks!
