Rich in NJ
Last month, while operating my '57 Powermaster (12-volt system, 4-post solenoid), it suddenly refused to start. I hadn't done any work on it recently, so no wires or associated components were touched or disturbed. Since I was in the middle of mowing my pastures, I was able to start it by using a single jumper cable to bypass the starting solenoid. Later, when I had some time, I did some troubleshooting and figured that I had a blown starting solenoid. I bought a new one and upon swapping it out with the bad one, the tractor started right up. About an hour later, when I went for another start, when I pressed the start button, nothing happened. I then bought another solenoid, and this time when it was swapped out, nothing happened when I pressed the button. Now I'm fuming, and what I did learn was that I could disconnect the ignition ("I") and starting ("S") leads off of the starting solenoid, temporarily touch the "I" lead to the "S" post on the solenoid, and the tractor would start immediately and run just as it always had. However, when both the leads were returned to their correct posts, again, the tractor would not start. So, today, I've spent two hours with my wiring diagram and meter, checking for any broken or failed wires - there were none. I also tested the solenoid more thoroughly, and it works just fine and clicks when 12 volts are applied. I removed the cover plate and shifter, and then removed the starting switch and tested it for continuity - it too was fine. I also verified that my key switch was working as well. So, I'm tearing my hair out on just what is wrong! It really seems the starting solenoid is the culprit, but nothing makes sense. Has anyone else experienced this? Any help would be greatly appreciated.
