1958 case terratrac 1000
Hello,
I have a 1958 case terratrac 1000, s/n 7100488. Reverse clutch on the right track went out and was wondering if anyone knows where I can get new replacement clutch disks?
Thank you, Dylan Preston
I recently bought an operators manual, a parts manual, and a service manual. Extremely helpful they are. I appreciate it though.
(quoted from post at 03:54:24 11/09/22)
Have you tried Steering Clutch.com?
Hi Jim,
So I did end up reaching out to steering clutch and unfortunately they had nothing for me. After calling every place I could turn up around the country I found one place, Con Equipment, in the Buffalo, NY area. They showed a listing for it, with the correct part numbers from my manual, and had two distributors that could get me parts, at this point I figured I was good to go. I got the parts and the disks are much skinnier and only the clutch plates have the correct outside diameter, clutch disks have a larger inside diameter and won t fit the drive sprocket. Must be from a newer model dozer? So in the end I believe I m on the hunt once again for the reverse clutches. Any other places that come to mind I can call would be greatly appreciated. Thank you.
Hi I'm new to this and I want to know if this is a activepost
(quoted from post at 13:29:05 02/12/23)
Hi Jim,
I know this is an older post but curious how you made out? Did you explore the possibility of having the clutch relined vs. buying a new one?
