I have the new style pump without a filter but the price to replace was pretty cheap and I wanted the filter so I bought the new pump.
It is identical aside from the filter and the filter housing. I'm having no luck getting it in though.
Do I need to remove the filter first to get it in or am I just not hitting the sweet spot?
I have had no luck finding a video of anyone installing one with the filter. Even the videos I found without a filter being removed or installed cut it out as they are having a hard time even with the non filter one.
I can remove and install the non filter in a minute. I assume the people in the videos lack the arm/hand strength to do it easily. With the filtered pump though it doesn't have room.
I'm going to remove the filter and give it a try today but I wanted to make sure I wasn't missing something. I did the lift pump, new piston/rings, and some other work after I got off work but the pump didn't go in easily and after 15 minutes I figured it was time to man the grill and the beer wasn't drinking itself.
This is my first tractor and I wouldn't be surprised if I'm missing something simple. I fixed the original pump(one of the clips holding the valve had half popped out and allowed the valve to pop up) but I'd like to use the new one.
Any advice?
Any advice?
