Hello, everyone. I have a 1965 175 with the Perkins diesel. The whole time I've had it, the lift has dropped when I press the clutch pedal to the second stage where it stops the hydraulic pump. I initially wasn't aware that this was abnormal operation for this tractor.
The last time I bushhogged last year, the hitch sort of gave out and wouldn't lift. I dragged the bushhog back to the barn and put it away. The next day, I started it up to try some diagnosis, and it was back to functioning as it had before it went out.
I pulled the side cover to discover that the lift cylinder was gushing oil, so it would only stay up at all if the pump was running. That seemed like the obvious problem I pulled the top cover, discovered that the o-ring on the piston was dried out, flat, cracked, and split all the way through in one spot. I replaced that o-ring on the piston and put everything back together what I thought was exactly how it came apart.
I started it to test how everything worked, and I discovered that the 3-point hitch wouldn't lift at all, but the PTO is working fine in the all the way back hydraulic power position. I loosened the stand pipe cover and initially had no oil coming out with the engine running. After a few seconds, it started flowing out, so I tightened the cap back down. I activated the remote valve and instantly blasted quite a lot of pressurized fluid out.
I pulled the side cover back off to see if I could determine anything obviously wrong, and the hitch magically lifted. I turned the tractor off, and it started to bleed down. I put the side cover back on, started the tractor back up, and the hitch lifted again. I then moved the position control lever half way down, and it stayed up. I moved it all the way down and stood on it, and it went down.
Now, the hitch does nothing with the control levers in any position, and nothing is coming up the stand pipe.
