RickHollerich
1973 Ford 5000. Replaced power steering pump a few months ago and has been working fine. Other day, while making a right turn in reverse, front tire hit a frozen runt that caused the tire and steering wheel to turn completely to right hitting the turn limit hard. After that, I could no longer turn the wheel to the right. It would turn fine to the left, but would not move at all to the right no matter what prostion I tried it from . Once it hit the left limit, I could not move the steering wheel at all.
I have verified that the tires and front end linkage works fine once disconnected from the power steering gear box.
While working on the power steering gear box, I found that once I relieve the oil pressure in the lower gearbox, by lossening the external pipe going to it and draining some of the oil out before tightening it back up, I could steer either way without problems, hitting both limits. However, once I started the tractor and worked to remove the air from the steering system by turning the steering wheel to the right and holding it at the limit for a while, the problem returned. Turns to the left without problems, but would not move to the right at all. It acts like once the gear box fills with oil, the oil is not getting returned to the pump when trying to turn to the right.
I did remove the return line to the pump, and I do get air and a little oil coming out the return port for a few seconds then nothing when turning right.
I did tear the unit down (see pictures), and as far as I can tell, everything looks good. No broken items, all o-rings and seals look good. All the ball bearings are accounted for and look good. I did verify that all the holes in the control valve are open by blowing air through them. Anybody have some suggestions on what is causing the right turn problem?
