new JD owner. I have a 1973 JD 1520 that acts fuel-starved after an hour or so of operation. once it cools some it will start and drive for only a few minutes if that. After sitting for several hours or overnight it runs great for about an hour then the symptoms come back. I replaced the fuel shut-off solenoid because the one on it was leaking at the wire and the insulation was worn through. The tank was drained and inspected with no issues found. No problem found with carb. There does not appear to be a fuel filter anywhere on the line. The tractor is not overheating. I have also tried loosening the fuel cap with no change.
