Thank you for accepting my application. I bought a 1974 MF135 perkins diesel a few months ago. Tractor starts on 2nd or third rev every time, runs up smooth and sounds great. Paint was gone, gauges were all frozen or broken (except tach which was new showing 33 hrs). Seller suggested previous owner indicated the engine had been overhauled a few years earlier and few hours had been put on it since. I know, I know but I only paid around $2700.00 for it so I went in with my eyes open. She sounded sooo good also. Sheet metal was solid with surface rust and mechanically the the tractor was solid so I invested some time and finished and repainted the tractor. Also replaced the gauges. I went to put it to work on the hunting club and this is where I need some help from any MF 135 experts out there, When first started the oil pressure reads in the upper 2/3 of green (no numbers on gauge). Over 20-25 min of working at 1900-2000 rpm (bush-hogging) the oil pressure slowly drops all the way down into the red (near zero). During this time the tractor sounds fine (no change in sound) ,never loses any power and continues to run cool. In fact it never really even gets up into the green on the gauge. I checked the gauge in boiling water before installing it and it worked fine. Thinking maybe my gauge was faulty I crossed my fingers and continued to work for about 6 hrs listening carefully and watching the temp which never changed. Never smoked or lost power or sounded funny. I had changed all fluids and oil filter and was running 10w40 deisil oil. I got home and deciced to change to straight 30w oil but with the same result except the oil pressure maybe was slightly higher but not much. I want to blame the gauge but it reads fine when first cranked. Also allowing the tractor to sit for as little as 5 min will cause the gauge to come up significantly when restarted (although it somewhat quickly begins to drop again). So I don't know if: 1) Faulty gauge 2) Worn oil pump (but pressure is high at first?) 3) Sticky relief valve 4) Excessive rod and main bearing wear. Any ideas.... I'm reasonably mechanical but not a lot of experience on tractors. Thank you so much for any help!
