2 tractors on 18' x 83" trailer
SDMike
Want to put a nf oliver 66 (3200lbs) and a nf jd H (2000lbs) on my trailer that has tandem 7200lb axles. Have others been able to put 2 NF tractors on a trailer together, sort of staggered, nose to nose?
thanks
thanks
I don’t see why not. 7200 lb axles would mean you have an overall weight limit of 14k or a little over. Trailer and tractors. Should fit no problem. We have an Ollie 88 we used to take to the pulls all the time. Just be careful if loading with no center ramp.
Hauled a H Farmall and a JD A a couple times, no problems, guys were impressed on how they were loaded. And if there was any doubts they would have let me know.
Not a problem will fit and the heavier one in front. I used to put 6 tractors on a single 48 foot stepdeck trailer with 1on the top deck and the front of the next one up beside it then finish with the last 4. Some were narrow fronts and some were wide. I had a B/N on the front top deck then a 1206 wide front up beside it and the other 4 on behind. I usually loaded some wides and narrows on the same loads. mostly smaller tractors like A's,B's H's M's and N series fords or fergies that size. Also had a 560 and 720 on in some of those loads.
